Hello SLReith. First disconnect the power to the unit. To gain access to the inside of the dryer, you will need to release the clips on the top of the bottom toe panel and pull the panel forward and lift it off the dryer. Next, remove the screws on the bottom of the front panel and pull the panel out and off the dryer. Once removed, you will need to unplug the door switch to remove the panel. You can now access the inside of the dryer. Here is a link to the parts diagram page to help you with the repair. Hope this helps. Cabinet parts replacement parts for MAYTAG MGDC700VW0 27" GAS DRYER | AppliancePartsPros.com
