I have a maytag dg482 dryer that works on all functions except the auto dry permanent press. I checked the vents and ducts and they are clear. The dryer doesn't turn off on this function (doesn't go to cool down mode) I suspect the cycling thermostat, but I don't really know. I also don't knowwhere this thermostat is mounted. can you help me?
