| » electric dryer will not start, hums |
I could not find any info on the given model number, please check it
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause. If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor. Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
| Display Modes | |
| Dryer hums, won't start | spearmint | Dryer Repair | 4 | 01-18-2011 08:08 PM |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| electric dryer only hums when started | nmesllc | Dryer Repair | 1 | 10-26-2009 05:59 PM |
| maytag gas dryer hums but wont start.. electric smell. | elsanto | Dryer Repair | 0 | 12-31-2007 06:49 AM |
| Dryer hums but doesn't start | bolinguist | Dryer Repair | 0 | 11-22-2007 04:06 PM |
