Discuss
Trb
 in
Dryer Repair
dryer will not heat up even after I replaced the heating element and thermostat that you sent me. Ads By
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Trb
  #1 (permalink)
Old 03-13-2009, 05:42 PM
Junior Member
trbandy is on a distinguished road
Default Trb
Model Number: LEQ8000HQ0   Brand: Whirlpool   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
  #2 (permalink)
Old 03-14-2009, 03:51 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LEQ8000HQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/...%203977704.pdf
I assume the unit does start rotating and you are only missing heat.
See Item 9 in Section 3 of the parts
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. A little late for this but better late than never.
You could unplug the unit, remove the wires from the thermal cutoff (fuse), short them together, tape them up so they cannot short to the frame, plug the unit in and give it a try.
If it is blown replace it ASAP as it is a safety device. Replace both as shown in Item 9.
__________________
  #3 (permalink)
Old 03-14-2009, 08:39 AM
Junior Member
Default
Denman,
Thank you for your support. I shorted the 2 wires together as suggested and it heated up immediately. My next question is, can you run the dryer for a period of time by bypassing the thermal cutoff or will it shorten the life of the heating element? Do I need to replace the thermal cutoff immediately or can we dry a few loads of clothes without it?
Again thank you for your support.
trbandy
  #4 (permalink)
Old 03-14-2009, 08:56 AM
Senior Expert
APP Volunteer
Default
You could do a few loads, problem is often a few loads turns into many loads.
I would also keep a close eye on it when doing this.
It should not effect the heating element but now that I have said that; it will (Murphy's Law)
So I do not recommend this as I would feel very guilty if something should happen.
Also clean and check your vent system and the blower wheel.
Lint filter, especially if you use fabric softener which can coat the filter screen and greatly reduce air flow. Would need to be cleaned with soap and water.
Also feel around the back and front of the drum to see if the seals are OK.
Often it is an air flow problem which causes the fuse to blow.
__________________
  #5 (permalink)
Old 03-14-2009, 09:00 AM
Junior Member
Default
Thanks again. We checked the vent system first thing,all was good, our lint filter is good.
Thanks for the help!!!!!!!!!!!!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
