markleyman
#1 Posted : Thursday, July 7, 2011 4:10:48 AM(UTC)
markleyman
my dryer does not operate when i press the start button. Do i need a new starter?
#2 Posted : Thursday, July 7, 2011 4:25:16 AM(UTC)
Replacement parts for WHIRLPOOL KEYE767WWH0 Residential Dryer | AppliancePartsPros.com
See the attachment for the wiring diagram.
Sorry I do not know what you mean by a "starter"
First I would check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next check that the door switch is working (turning the light off). This just tells you that it is being activated and not that the normally open contacts are closing.
Next check the thermal fuse (Item 6 in Section 4)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
File Attachment(s):
KEYE767.pdf (51kb) downloaded 16 time(s).
Kitchenaid dryer doesn't heat (Dryer Repair)
by Snakebone 11/8/2012 11:40:23 AM(UTC)
by Snakebone 11/8/2012 11:31:10 AM(UTC)
Kitchenaid dryer stop before clothes are dry (Dryer Repair)
by mark987 10/5/2012 6:17:51 AM(UTC)
KitchenAid dryer won't start (Dryer Repair)
by ljrm 1/15/2012 7:38:57 PM(UTC)
kitchenaid dryer-element gone bad? (Dryer Repair)
by arlacrane 1/21/2011 8:33:55 AM(UTC)
Kitchenaid Dryer (Dryer Repair)
by pappy11 1/15/2011 10:35:58 AM(UTC)
Kitchenaid dryer won't dry clothes completely (Dryer Repair)
by timandjulie 1/16/2010 9:25:13 AM(UTC)
KitchenAid Dryer taking several cycles to dry clothes (Dryer Repair)
by tlaffey 1/4/2010 7:06:25 AM(UTC)
KitchenAid Dryer Belt (Dryer Repair)
by gkledaras 8/20/2009 4:54:54 AM(UTC)
KitchenAid dryer slow start up and quick stop (Dryer Repair)
by kaceyjo78 2/13/2009 10:14:31 AM(UTC)
