Discuss
Dryer Rattling & Grinding Noise
 in
Dryer Repair
Hi ********************, My Norge Dryer Model DEM204W making continuous grinding noise and rattling noise. I am thinking DRUM is touching
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Rattling & Grinding Noise
  #1 (permalink)
Old 03-11-2009, 08:33 PM
Junior Member
Avatar3 is on a distinguished road
Post Dryer Rattling & Grinding Noise
Model Number: DEM204W   Brand: Norge   Age: 5 - 10 years
My Norge Dryer Model DEM204W making continuous grinding noise and rattling noise. I am thinking DRUM is touching with some thing because seeing the mark on the DRUM. Noise loud or low depend on the load of cloths.
I opened the top cover and front cover but not able to open the DRUM to check the pullys or any other went down and touching something.
Please help me with instruction how to remove the DRUM in the Norge Dryer, model: DEM204W and what could be the other possible problem or to check or replace. I will really appreciate your help. Thanks . Looking forward to hear from your soon.
Related Models
Norge DEM204W DRYER- ELE
Norge DEM204WC DRYER- ELE
Norge DEM205A DRYER- ELE
Norge DEM205AC DRYER- ELE
Norge DEM205W DRYER- ELE
Norge DEM205WC DRYER- ELE
Norge DEN202A DRYER- ELE
Norge DEN202AC DRYER- ELE
Norge DEN202W DRYER- ELE
Norge DEN202WC DRYER- ELE
Norge DEN203A DRYER- ELE
Norge DEN203AC DRYER- ELE
Norge DEN203W DRYER- ELE
Norge DEN203WC DRYER- ELE
Norge DEN204A DRYER- ELE
Norge DEN204GV DRYER- ELE
Norge DEN204KA DRYER- ELE
Norge DEN204KV DRYER- ELE
Norge DEN204V DRYER- ELE
Norge DEN204VC DRYER- ELE
Norge DEN204W DRYER- ELE
Norge DEP222VC DRYER- ELE
Norge DEP223M DRYER- ELE
Norge DEP223V DRYER- ELE
Norge DEP224V DRYER- ELE
Norge DEP224VC DRYER- ELE
Frigidaire DES100CD1 Kel(v2) / Electric Dryer
Frigidaire DES100CW1 Kel(v1) / Electric Dryer
Frigidaire DES100FD2 Kel(v2) / 27 " Dryer
Frigidaire DES100FW2 Kel(v1) / 27 " Dryer
Amana DES11E COMMERCIAL MICROWAVES
Menu Master DES11EA COMMERCIAL MICROWAVES
Frigidaire DESFL0 Frg(v6) / Electric Dryer
Frigidaire DESFL1 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFL3 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL4 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFW0 Frg(v5) / Electric Dryer
Frigidaire DESFW1 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFW3 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW4 Frg(v5) / 27 " Electric Dryer
Frigidaire DET100KD1 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KD2 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KW1 Kel(v3) / 27 " Electric Dryer
Frigidaire DET100KW2 Kel(v3) / 27 " Electric Dryer
Frigidaire DET250K1D Kel(v2) / 27 " Electric Dryer
Frigidaire DET250K1W Kel(v1) / 27 " Electric Dryer
Frigidaire DET400A0D Kel(v8) / Dryer
Frigidaire DET400A0T Kel(v9) / Dryer
Frigidaire DET400A0W Kel(v10) / Dryer
Frigidaire DET400A1D Kel(v9) / Dryer
Frigidaire DET400A1T Kel(v10) / Dryer
Frigidaire DET400A1W Kel(v11) / Dryer
Frigidaire DET400A2D Kel(v9) / Electric Dryer
Frigidaire DET400A2T Kel(v10) / Electric Dryer
Frigidaire DET400A2W Kel(v11) / Electric Dryer
Frigidaire DET400F1D Kel(v12) / Electric Dryer
Frigidaire DET400F1W Kel(v10) / Electric Dryer
Frigidaire DET400F2D Kel(v11) / Electric Dryer
Frigidaire DET400F2W Kel(v10) / Electric Dryer
Frigidaire DET400G1D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G1J Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G1W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G2D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G2W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G3D Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G3J Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G3W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G4D Kel(v6) / 27 " Electric Dryer
Frigidaire DET400G4W Kel(v5) / 27 " Electric Dryer
Frigidaire DET400KD1 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD2 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD3 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KW1 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW2 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW3 Kel(v1) / 27 " Electric Dryer
Maytag DF10AALWH FREEZER- VERTICAL
Maytag DF10ABLWH FREEZER- VERTICAL
Maytag DF10ABLWHT FREEZER- VERTICAL
Maytag DF10BBLWHT FREEZER- VERTICAL
Maytag DF12ABLWH FREEZER- VERTICAL
Maytag DF12ACLWH FREEZER- VERTICAL
Maytag DF12ACLWHT FREEZER- VERTICAL
Maytag DF12BCLWHT FREEZER- VERTICAL
Maytag DF12H FREEZER- VERTICAL
Maytag DF12J FREEZER- VERTICAL
Maytag DF15AAL-WH FREEZER- VERTICAL
Maytag DF15ABLWH FREEZER- VERTICAL
Maytag DF15ACLWH FREEZER- VERTICAL
Maytag DF15ADLWH FREEZER- VERTICAL
Maytag DF15ADLWHT FREEZER- VERTICAL
Maytag DF15ASLWH FREEZER- VERTICAL
Maytag DF15ATLWH FREEZER- VERTICAL
Maytag DF15ATLWHT FREEZER- VERTICAL
Maytag DF15AUMALT FREEZER- VERTICAL
Maytag DF15AUMWHT FREEZER- VERTICAL
Maytag DF15BDLWHT FREEZER- VERTICAL
Maytag DF15BE FREEZER- VERTICAL
Maytag DF15BPB FREEZER- VERTICAL
Maytag DF15BTLWHT FREEZER- VERTICAL
  #2 (permalink)
Old 03-12-2009, 04:41 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Well if you have the top up. Look inside the front of the front panel, up top in the left hand corner, about 6 inches down, and there will be a screw there to release the front on that side. Remove it. Do the same on the other side. Pull the front toward you, and take the wires off the door switch. The get on your knees, and reach in a push the idler pully to release the tention on the belt, and then remove the belt, and pull the drum out. You will most likely have to replace the rollers. Also make sure the idler pully wheel, is spining good too. Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitates but Grinding/Rattling sound MesaGuy Washer Repair 8 01-04-2010 01:29 PM
Dryer making squeaking and or grinding noise jodyddaniels Dryer Repair 1 01-04-2010 05:15 AM
Ge Front Load Dryer Making Grinding Noise JWATSON Dryer Repair 2 09-30-2009 04:20 PM
Maytag stackable washer dryer makes rattling noise anniesmomrocks Dryer Repair 6 08-06-2009 09:15 AM
Dryer Is Making A Grinding Noise IAFF991 Dryer Repair 2 04-04-2009 05:44 AM
