Discuss
dryer starts than stops
 in
Dryer Repair
WHEN YOU PUSH THE START BUTTON - DRYER STARTS - WHEN YOU LET OFF - THE DRYER STOPS - WHEN
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer starts than stops
  #1 (permalink)
Old 03-11-2009, 10:48 AM
Junior Member
douglasrunion is on a distinguished road
Default dryer starts than stops
Model Number: 160.63952102   Brand: Kenmore   Age: 5 - 10 years
WHEN YOU PUSH THE START BUTTON - DRYER STARTS - WHEN YOU LET OFF - THE DRYER STOPS - WHEN YOU HOLD START BUTTON ON THERE IS HEAT - 1 OUT OF 5O TIMES THE DRYER WILL STAY ON AND WILL WORK RIGHT WHEN START BUTTON IS PUSHED
Ads By Google
Related Models
Amana 1607.000 Mwave - Family Size (60 Hz)
Amana 1607.001 Mwave - Family Size (60 Hz)
Amana 1608.000 Mwave - Family Size (60 Hz)
Amana 1608.001 Mwave - Family Size (60 Hz)
Amana 1608.002 Mwave - Family Size (60 Hz)
Amana 1608.004 Mwave - Family Size (60 Hz)
Amana 1609.000 Mwave - Family Size (60 Hz)
Amana 1609.001 Mwave - Family Size (60 Hz)
Amana 1618.000 Mwave - Family Size (60 Hz)
Amana 1618.001 Mwave - Family Size (60 Hz)
Amana 1618.002 Mwave - Family Size (60 Hz)
Amana 1618.004 Mwave - Family Size (60 Hz)
Whirlpool 1633W0A
Whirlpool 1633W1A
Whirlpool 1633W2A
Whirlpool 1633^0A
Whirlpool 1633^1A
Whirlpool 1633^2A
Amana 1635.000 Mwave - Family Size (60 Hz)
Amana 1635.001 Mwave - Family Size (60 Hz)
Amana 1636.000 Mwave - Family Size (60 Hz)
Amana 1636.001 Mwave - Family Size (60 Hz)
Amana 1639.000 Mwave - Family Size (60 Hz)
Amana 1639.001 Mwave - Family Size (60 Hz)
Amana 1639.002 Mwave - Family Size (60 Hz)
Amana 1639.004 Mwave - Family Size (60 Hz)
Whirlpool 1643W0A
Whirlpool 1643W1A
Whirlpool 1643W2A
Whirlpool 1643^0A
Whirlpool 1643^1A
Whirlpool 1643^2A
Whirlpool 1653W0A
Whirlpool 1653W1A
Whirlpool 1653W2A
Whirlpool 1653^0A
Whirlpool 1653^1A
Whirlpool 1653^2A
Hoover 168691 Electrolux/refrigerator
Magic Chef 16RA-3B Rv Range - Gas
Magic Chef 16RA-3B-49 Rv Range - Gas
Magic Chef 16RA-3BK Rv Range - Gas
Magic Chef 16RA-3BKZ Rv Range - Gas
Magic Chef 16RA-3BT Rv Range - Gas
Magic Chef 16RA-3BT49 Rv Range - Gas
Magic Chef 16RA-3BTZ Rv Range - Gas
Magic Chef 16RA-3BZ Rv Range - Gas
Magic Chef 16RA-4 Rv Range - Gas
Magic Chef 16RA-4K Rv Range - Gas
Magic Chef 16RA-4KZ Rv Range - Gas
Magic Chef 16RA-4T Rv Range - Gas
Magic Chef 16RA-4TZ Rv Range - Gas
Magic Chef 16RA-4Z Rv Range - Gas
Magic Chef 16RB-3B Rv Range - Gas
Magic Chef 16RB-3BK
Magic Chef 16RB-3BKZ
Magic Chef 16RB-3BT Rv Range - Gas
Magic Chef 16RB-3BTZ Rv Range - Gas
Magic Chef 16RB-3BZ Rv Range - Gas
Magic Chef 16RB-4 Rv Range - Gas
Magic Chef 16RB-4K
Magic Chef 16RB-4KZ Rv Range - Gas
Magic Chef 16RB-4T
Magic Chef 16RB-4TZ Rv Range - Gas
Magic Chef 16RB-4Z Rv Range - Gas
Magic Chef 16RS-4 Rv Range - Gas
Magic Chef 16RS-4K Rv Range - Gas
Magic Chef 16RS-4KZ
Magic Chef 16RS-4T Rv Range - Gas
Magic Chef 16RS-4TZ
Magic Chef 16RS-4Z Rv Range - Gas
Magic Chef 16RW-3B Rv Range - Gas
Magic Chef 16RW-3B-49 Rv Range - Gas
Magic Chef 16RW-3BK Rv Range - Gas
Magic Chef 16RW-3BKZ Rv Range - Gas
Magic Chef 16RW-3BT Rv Range - Gas
Magic Chef 16RW-3BT49 Rv Range - Gas
Magic Chef 16RW-3BTZ Rv Range - Gas
Magic Chef 16RW-4 Rv Range - Gas
Magic Chef 16RW-4K Rv Range - Gas
Magic Chef 16RW-4KZ Rv Range - Gas
Magic Chef 16RW-4T Rv Range - Gas
Magic Chef 16RW-4TZ Rv Range - Gas
Magic Chef 16RW-4Z Rv Range - Gas
Magic Chef 16TA-3B-49 Rv Range - Gas
Magic Chef 16TA-3BK49 Rv Range - Gas
Magic Chef 16TA-3BZ Rv Range - Gas
Magic Chef 16TA-4Z Rv Range - Gas
Magic Chef 16TB-3B Rv Range - Gas
Magic Chef 16TB-3BK Rv Range - Gas
Magic Chef 16TB-3BZ Rv Range - Gas
Magic Chef 16TB-4 Rv Range - Gas
Magic Chef 16TW-3B Rv Range - Gas
Magic Chef 16TW-3B-49 Rv Range - Gas
Magic Chef 16TW-3BK Rv Range - Gas
Magic Chef 16TW-3BK49 Rv Range - Gas
Magic Chef 16TW-3BKE Rv Range - Gas
Magic Chef 16TW-3BKZ Rv Range - Gas
Magic Chef 16TW-3BZ Rv Range - Gas
Magic Chef 16TW-4KZ Rv Range - Gas
Thermador 1701
Amana 1708.000 Mwave - Family Size (60 Hz)
Amana 1708.001 Mwave - Family Size (60 Hz)
Amana 1709.000 Mwave - Family Size (60 Hz)
Amana 1709.001 Mwave - Family Size (60 Hz)
Amana 1718.000 Mwave - Family Size (60 Hz)
Amana 1718.001 Mwave - Family Size (60 Hz)
Amana 1720.000 Mwave - Family Size (60 Hz)
Amana 1736.000 Mwave - Family Size (60 Hz)
Amana 1736.001 Mwave - Family Size (60 Hz)
Amana 1739.000 Mwave - Family Size (60 Hz)
Amana 1739.001 Mwave - Family Size (60 Hz)
Whirlpool 1743W0A
Whirlpool 1745W0A
Whirlpool 1745^0A
Amana 1750.000 Mwave - Family Size (60 Hz)
Amana 1752.000 Mwave - Family Size (60 Hz)
Amana 1752.001 Mwave - Family Size (60 Hz)
Whirlpool 1765W0A
Whirlpool 1765^0A
  #2 (permalink)
Old 03-11-2009, 11:51 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a tech sheet
https://www.servicematters.com/docs/...%203980052.pdf
Take a look at the tech sheet wiring diagram lower left corner, you will see the PTS (Push To Start) switch in parallel with it is the MOTOR RELAY contacts.
Perhaps the relay is shot.
Note the board senses when the Push To Start is activated and it closes the MOTOR RELAY.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer starts then stops drewmar Dryer Repair 2 10-04-2009 06:55 AM
GE Gas Dryer starts & stops, etc. danjaxson Dryer Repair 0 03-15-2009 12:11 PM
Dryer. . .starts Then Stops PPHILLIPS232 Dryer Repair 6 11-13-2008 12:34 PM
Dryer starts to dry then stops Bryan507 Dryer Repair 1 06-20-2008 04:18 PM
Dryer starts then stops Redwings19 Dryer Repair 0 09-20-2007 09:09 AM
