i have a kenmore 70 series dryer once the cycle is done the timer keeps going and when it goes to the next cycle it turns on the heating element so i have to unplug it from the wall when it is done to prevent a fire i think the timer is gone out but i want to know if there is a way to test it before i spend 100+ on a part i dont need i have replaced the termal fuse because it blew out and wouldnt start at all then this started happening any help would be greatly appreciated
What is the complete model number of the dryer?
the model number is 11066712694 70 series not sure of the year i bought it used i do have mechanical backround just not on appliances so i really appreciate the help!
Would it stop if you open the door?
If it would, would it start by itself as soon as you close the door?
if you are asking about the ticking while not in use then no, the opening and closing of the door has no effect on it it just ticks on and on as long as it is plugged in, however if you start it and open the door it turns off the cycle but still ticks
Originally Posted by: Gene ...If it would, would it start by itself as soon as you close the door?... You did not answer this question. Gene.
ok are you talking about when the dryer is running will it turn off when i open the door or when the timer is ticking?
When the dryer is running.
