Register | FAQ's | New Posts | Today's Posts | Extras |
» Dryer does not heat up |
![]() Model Number: LER331DS0 Brand: Frigidaire Age: 1 - 5 years
![]() Drum turns but no heat . Is there a sequence for troubleshooting the circuit? Can it be checked from behind the control panel by selecting particular switch settings to determine if the heating element is good/bad or the thermostats are good/bad? What other elements may be involved with the lack of heat? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here are your parts
Replacement parts for FRG LER331DS0 | AppliancePartsPros.com Here is a wiring diagram http://ftp.electrolux-na.com/PDFnotF...odel=LER331DS0 Does the drum light work? Does the timer advance in Timed Dry mode? Does the timer advance in Auto mode? Can it be checked from behind the control panel by selecting particular switch settings to determine if the heating element is good/bad or the thermostats are good/bad? If timer advances in Auto mode then odds are high that the heating element is good as the timer gets power through the element in this mode What other elements may be involved with the lack of heat? Here is your circuit path for the heating element when motor is running: L2 , M2/M1 motor's centrifugal switch , HEATER , HIGH LIMIT THERMOSTAT , CONTROL THERMOSTAT , A/B timer contacts , L1
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
