The start switch on this model is designed to push in and turn to snap into the housing for mounting. It is also designed to make about a 1/2" turn of the knob to the right to turn on the dryer, spring switch. However, users often put too much pressure on the switch resulting in the switch being turned more than 1/2" which ends up twisting the entire switch right out of the switch's mounting. Tired of fixing this issue EVERY WEEK!
I would like to replace this switch with a simple push button switch but have no idea which one to order. Can someone help me with this please.
Thanks, Greatly appreciated - Mike
