| » dryer start button noise - dryer won't run |
Model Number: LER5636EQ3 Brand: Whirlpool Age: 5 - 10 years
After a day or two of making an intermittent squeaking/squealing noise while running, now, when i press the start button, it makes a loud buzzing noise (like the noise when the load is finished) and it sounds like the motor will not engage and turn the drum. Any ideas? Thanks!
Replacement parts for WHIRLPOOL LER5636EQ3 | AppliancePartsPros.com Sounds like your motor has bit the dust. This may take two people. Try rotating the drum by hand, it should rotate fairly easily. If OK Open the door, hold the door switch closed, push the start switch and rotated the drum in the correct direction. Watch your hands in case it starts up. If it does start then odds are high that you need a new motor.
__________________
Thanks! I'll give it a go and see what happens - will post outcome.
The verdict is in - the drum turned freely before proceeding to step 2. While holding the door switch closed and presssing the start button, the drum started up and began turning. Since there was no load on the drum, I went a step further and applied some light resistance to the drum, while repeating step two, and the drum would not turn - causing the start switch to trip off and not respond (for lack of a better technical description). Thank you for your help! BR Last edited by brhodes58 : 03-11-2009 at 08:38 AM. |
Yes it looks like the motor needs replacing but at $80.00 it is probably worth replacing if the rest of the unit is in good shape.
I would check the belt, rear rollers, idler wheel, drum seals etc. for slop and wear and replace as necessary. Then you will know the total cost to give it an overhaul. Also give the interior a good cleaning and clean/check your vent system.
__________________
This should help
http://www.applianceaid.com/wpmotor-change.html
__________________
| Display Modes | |
| HOT POINT DRYER has power but start button doesn't start the dryer. | HOT POINT | Dryer Repair | 2 | 08-01-2011 06:47 PM |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| dryer start but stops when I release start button | vchss360 | Dryer Repair | 7 | 10-20-2009 03:46 AM |
| Dryer has humming noise when start button is push | jgaines | Dryer Repair | 1 | 06-21-2009 03:53 PM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
