Discuss
what should i replace first
 in
Dryer Repair
my dryer is making a roaring sound while running.can someone tell me if i should start replacing the 2 rear
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » what should i replace first
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-30-2011, 01:54 PM
Junior Member
adamkorreckt is on a distinguished road
Default what should i replace first
Model Number: sde3606ayw   Brand: Maytag   Age: 5 - 10 years
my dryer is making a roaring sound while running.can someone tell me if i should start replacing the 2 rear rollers or the blower fan, or any other suggestions would be great. the belt looks fine. I have't seen any other forums about the motors making noises, does anyone no how to tell.
Related Models
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
  #2 (permalink)
Old 07-01-2011, 09:07 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Adam,
Where does the noise seem to be coming from, the front or back of the cabinet ?
A good indication of a bad blower wheel, when you open the door, or the machine stops, you'll hear a rumbling noise for a second or so, and it may make a similar noise at the very start of the cycle.
Part number: AP4062362
If the noise is present during the complete cycle, and there's no noise when the dryer stops, it a very good chance, the drum rollers are worn out and need repalcement.
Part number: AP4046756
Besides, when you start the teardown procedure, you'll get to the blower assembly, before you get to the rear roller assemblies.
Thanks,
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-01-2011, 09:11 AM
Junior Member
Default
i think the noise is coming from the rear which would be the rollers. they look fine when i took it apart but i didn't take the drum off so may be they might be worn in a few places.thanks for the advice.
  #4 (permalink)
Old 07-01-2011, 11:15 AM
Senior Expert
Default
Adam,
Good deal.
You do need to remove the drum and rollers, to get a "proper" look at the roller bearing interior surface, and the condition of the roller shaft, as well.
You'll do fine.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 10-19-2011, 04:19 PM
Junior Member
mabbit is on a distinguished road
Default Removing front panel from Amana Model ALG 443 RAW Gas and Electric Dryer
I found the following directions on this forum to help install
a Drum Support Roller Part Number:AP4046756
into a Amana Model ALG 443 RAW Gas and Electric Dryer
"You will need to raise the top of the dryer, and remove the screws holding the front panel in place. "
I can't access the screws that hold the front panel in place. I was able to lift the top, but could not reach any screws after that.
Does anyone know how to get to those screws?
  #6 (permalink)
Old 10-20-2011, 06:40 AM
Senior Expert
Default
Mabbit,
Here are some basic service manual excerpts, it should get you through.
The screws you're working with are actually on the front cabinet frame and on the bottom of the upper front panel.
FRONT PANEL AND PANEL SEAL
a. While supporting the lower access panel, remove two screws from bottom edge of lower access panel,
b. Gently lower the access panel to disengage guide lugs from bottom edge of front panel.
c. Remove two screws holding bottom tabs on front panel to dryer side panels,
Swing bottom of front panel away from dryer far enough to disengage hold-down clips and guide lugs from cabinet top.
d. Disconnect wires from door switch .
e.
Disconnect wires to cylinder light (if applicable).
f. Disconnect wires from moisture sensor (if applicable).
g. Disengage belt from motor and idler pulleys,
h. Remove four screws holding bulkhead to front flange of cabinet and lift complete bulkhead assembly out of slots in cabinet.
Good Luck,
__________________
Joe M. APP TEAM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace an EOC? Jefflaur1 Oven Repair (including Ranges and Cooktops) 3 04-21-2011 06:00 PM
How to replace the upper and how to replace lower arms Anna Banana Dishwasher Repair 0 08-17-2010 11:34 AM
Do I need to Replace the $$ EOC $$ ? chris76108 Oven Repair (including Ranges and Cooktops) 2 06-27-2009 10:58 AM
Need help with what to replace Philibi4 Dryer Repair 2 05-02-2009 04:49 AM
Replace SDG Washer Repair 4 12-30-2008 07:58 AM
