Discuss
Dryer heat blows hot then cold
 in
Dryer Repair
It's a tunnel looking part that glows orange ... then fades. This action was Audibly clicking on and off as
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heat blows hot then cold
  #1 (permalink)
Old 03-09-2009, 01:07 PM
Junior Member
scri8e is on a distinguished road
Question Dryer heat blows hot then cold
Model Number: ZG2109W   Brand: Speed Queen   Age: More than 10 years
It's a tunnel looking part that glows orange ... then fades. This action was Audibly clicking on and off as well as the orange glow clicking on and fading. This is the igniter I am told.
Never worked on a dryer before. I'm a Landlord of several Multi dwellings that bought used coin op SQ washer and Dryer 6 months ago.
Wanted to dump Webb Laundry Service. Which I am delighted I did.
Here is a photo:
http://s344.photobucket.com/albums/p...failedPart.jpg
Upon further postings in other forums. ...
Quote:
Sequence for "glow bar" ignition is: 1 Dryer call for heat and glow bar heats up. 2. Sensor calls for gas valve to open. 3. Burners ignite and sensor calls for gas valve to stay open. If glow bar only glows part way it is bad. If you hear the gas valve open and then ignitor goes cold you may have to reposition glow bar a little. Burner may be clogged in area under glow bar, therefore no ignition. These are the basics. Look at the ones that work and you'll understand. CAUTION: Glow bar is very hot for a long time after it is no longer glowing (trust me). good luck, Brett
[ / Quote ]
I noticed from the picture that what looked to be the end of the gas valve seemed to be clogged with lint. So I took a shop vac with a fine tip with a brush to the under area and got all lint sucked up and out. I took a pin (dryer unplugged for safety of course.) and cleaned out the gas valve end. Plugged in the dryer put a quarter in and fired it up. The gas ignited right off. Yay. However it stayed on for a short while. Then went off. When I smacked the black C battery looking part the gas ignited again then went off. So following the path that Brett set out above it would be the sensor that is bad correct?
Or should I just replace the Igniter and the sensor while I'm doing the repair? I don't know how old the machines are as I bought them used. Does the serial number tell you the year the unit was made in? Like a car vin number does?
Ads By Google
Related Models
General Electric ZGG24L20B2SS Gas range
General Electric ZGG24L20BSS Gas range
General Electric ZGG27L20ASS Gas range
General Electric ZGG27L20C2SS Gas range
General Electric ZGG27L20C3SS Gas range
General Electric ZGG27L20CSS Gas range
General Electric ZGG27L20YSS Gas range
General Electric ZGG27L21ASS Gas range
General Electric ZGG27L21C2SS Gas range
General Electric ZGG27L21C3SS Gas range
General Electric ZGG27L21CSS Gas range
General Electric ZGG27L21YSS Gas range
General Electric ZGG27N20C2SS Gas range
General Electric ZGG27N20C3SS Gas range
General Electric ZGG27N20CSS Gas range
General Electric ZGG27N20YSS Gas range
General Electric ZGG27N21C2SS Gas range
General Electric ZGG27N21C3SS Gas range
General Electric ZGG27N21CSS Gas range
General Electric ZGG27N21YSS Gas range
General Electric ZGG36L20ASS Gas range
General Electric ZGG36L20CSS Gas range
General Electric ZGG36L20YSS Gas range
General Electric ZGG36L21ASS Gas range
General Electric ZGG36L21C2SS Gas range
General Electric ZGG36L21CSS Gas range
General Electric ZGG36L21YSS Gas range
General Electric ZGG36L30ASS Gas range
General Electric ZGG36L30CSS Gas range
General Electric ZGG36L30YSS Gas range
General Electric ZGG36L31ASS Gas range
General Electric ZGG36L31C2SS Gas range
General Electric ZGG36L31CSS Gas range
General Electric ZGG36L31YSS Gas range
General Electric ZGG36N20CSS Gas range
General Electric ZGG36N20YSS Gas range
General Electric ZGG36N21C2SS Gas range
General Electric ZGG36N21CSS Gas range
General Electric ZGG36N21YSS Gas range
General Electric ZGG36N30CSS Gas range
General Electric ZGG36N30YSS Gas range
General Electric ZGG36N31C2SS Gas range
General Electric ZGG36N31CSS Gas range
General Electric ZGG36N31YSS Gas range
General Electric ZGG48L30ASS Gas range
General Electric ZGG48L30CSS Gas range
General Electric ZGG48L30YSS Gas range
General Electric ZGG48L31ASS Gas range
General Electric ZGG48L31C2SS Gas range
General Electric ZGG48L31CSS Gas range
General Electric ZGG48L31YSS Gas range
General Electric ZGG48L40ASS Gas range
General Electric ZGG48L40CSS Gas range
General Electric ZGG48L40YSS Gas range
General Electric ZGG48L42ASS Gas range
General Electric ZGG48L42C2SS Gas range
General Electric ZGG48L42CSS Gas range
General Electric ZGG48L42YSS Gas range
General Electric ZGG48N30CSS Gas range
General Electric ZGG48N30YSS Gas range
General Electric ZGG48N31C2SS Gas range
General Electric ZGG48N31CSS Gas range
General Electric ZGG48N31YSS Gas range
General Electric ZGG48N40CSS Gas range
General Electric ZGG48N40YSS Gas range
General Electric ZGG48N42C2SS Gas range
General Electric ZGG48N42CSS Gas range
General Electric ZGG48N42YSS Gas range
General Electric ZGH1LYSS Gas range
General Electric ZGH1NYSS Gas range
General Electric ZGH2LYSS Gas range
General Electric ZGH2NYSS Gas range
General Electric ZGS30L4ASS Gas range
General Electric ZGS30N4ASS Gas range
General Electric ZGU3650BB0BG Gas range
General Electric ZGU3650BB1BG Gas range
General Electric ZGU3650WB0WG Gas range
General Electric ZGU3650WB1WG Gas range
General Electric ZGU365DBB0BG Gas range
General Electric ZGU365DBB1BG Gas range
General Electric ZGU365DWB0WG Gas range
General Electric ZGU365DWB1WG Gas range
General Electric ZGU36GGBD1BB Gas range
General Electric ZGU36GGSD1SS Gas range
General Electric ZGU36GGTD1WW Gas range
General Electric ZGU36KBK1BB Gas range
General Electric ZGU36KBK2BB Gas range
General Electric ZGU36KSK1SS Gas range
General Electric ZGU36KSK2SS Gas range
General Electric ZGU36KWK1WW Gas range
General Electric ZGU36KWK2WW Gas range
General Electric ZGU36L4DD1SS Gas range
General Electric ZGU36L4DH1SS Gas range
General Electric ZGU36L4DH2SS Gas range
General Electric ZGU36L4DH3SS Gas range
General Electric ZGU36L4DH4SS Gas range
General Electric ZGU36L4DYSS Gas range
General Electric ZGU36L4RD1SS Gas range
General Electric ZGU36L4RD2SS Gas range
General Electric ZGU36L4RH1SS Gas range
General Electric ZGU36L4RH2SS Gas range
General Electric ZGU36L4RH3SS Gas range
General Electric ZGU36L4RH4SS Gas range
General Electric ZGU36L4RYSS Gas range
General Electric ZGU36L6D1SS Gas range
General Electric ZGU36L6H1SS Gas range
General Electric ZGU36L6H2SS Gas range
General Electric ZGU36L6H3SS Gas range
General Electric ZGU36L6H4SS Gas range
General Electric ZGU36L6YSS Gas range
General Electric ZGU36N4DD1SS Gas range
General Electric ZGU36N4DH1SS Gas range
General Electric ZGU36N4DH2SS Gas range
General Electric ZGU36N4DH3SS Gas range
General Electric ZGU36N4DH4SS Gas range
General Electric ZGU36N4DYSS Gas range
General Electric ZGU36N4RD1SS Gas range
General Electric ZGU36N4RD2SS Gas range
General Electric ZGU36N4RH1SS Gas range
General Electric ZGU36N4RH2SS Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Won't Heat, Blows Cold Air ramonamahoney@rocketmail. Dryer Repair 4 01-29-2010 01:33 AM
dryer blows but its cold just happend billy31 Dryer Repair 1 12-23-2009 05:02 AM
Blows air but it's cold! Palmettoquilter Dryer Repair 2 12-22-2009 10:11 PM
Dryer won't Heat tumbles and blows air though stacyvelazco Dryer Repair 5 06-30-2009 05:52 AM
dryer blows cold air won't advance through cycle sandra626 Dryer Repair 4 02-05-2008 10:49 AM
