Discuss
Dryer Belt Diagrams
 in
Dryer Repair
What the heck does this message have to do with appliance repair ?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Belt Diagrams
  #21 (permalink)
Old 12-15-2013, 08:14 PM
Senior Member
thorning is on a distinguished road
Default
  #22 (permalink)
Old 07-06-2014, 08:37 AM
Junior Member
TommyK is on a distinguished road
Default Yeah, but how do I INSTALL it?
Is there a trick to getting the tension arm pulled back so I can wrap it around all pullies/drum correctly.
The last time I did it, it was B-E-A-R. How do the pros do it without cursing Frigidaire and leaving a pound of knuckle flesh in the cabinet?
Mine's a Frigidaire with the pulley wa-a-a-ay in the back. FEZ831AS1
I also need to know how and with what to lube the drum bearing.
  #23 (permalink)
Old 07-06-2014, 09:57 AM
Senior Member
Default
There is no easy way to get the belt on with a lot of models unless it is open at the back end. I usually try to get them on with no shirt sleeves to get tangled up and I still have trouble on some models.
I have never used any lube on the idler pulley as most of them are self lubing . If you need a diagram of the belt routing there is a nice diagram on the web . Use Google and you can find it for many different brands and models.
Are you sure you have the correct length belt ? Best to compare the new one if you are replacing it to the old one. Good luck . Sometimes it takes me 15 or 20 minutes with a lot of cussing to do it.
  #24 (permalink)
Old 07-07-2014, 05:47 AM
Junior Member
Default As luck would have it.
There is a access door at the back. Woot! Thanks Frigidaire!
The 'knuckle buster' I was thinking of must have been a previous dryer.
The bearing I need to grease is the ball bearing at the center axle of the drum. Would 'high temp' automobile wheel bearing grease be good to use? I hate to experiment too much, as I don't want it to be not 'high temp' enough, liquify, run down and into the element, thus smoking up the place, or worse, catch fire.
  #25 (permalink)
Old 07-07-2014, 05:56 AM
Senior Member
Default
TO MY KNOWLEDGE THESE ARE SEALED BEARINGS AND NO LUBE CAN BE ADDED. IF YOUR BEARING IS ROUGH OR NOISY IT WILL HAVE TO BE REPLACED.
  #26 (permalink)
Old 01-16-2015, 05:36 AM
Senior Member
Default
The typical GE dryer uses a center mount bearing at the rear of the drum and it is not a sealed bearing. Some of these get squeaky when they are in use a long time. A small amount of lube can be used on the bearing which is put in the cup section before the drum is installed. I use a high temp wheel bearing grease but not too much. Previously I said it was a sealed bearing but at least the old units are not sealed.
  #27 (permalink)
Old 01-18-2015, 12:47 PM
Senior Member
Default
I was working on a Frigidaire electric dryer model number GLER341AS1 that had a bad heating coil . In checking the parts cost it turned out to be too expensive to repair so I scrapped the unit after taking out any usable parts. The motor was OK and I attempted to use the motor in a Amana electric dryer model ALE230RAW. It would fit in the support cradle area but much to my disappointment I found out that the motor shaft threaded end was slightly different between these two makes of dryers. The thread on the end of the shaft is screwed into the plastic blower wheel. The diameter of the thread on the shaft is the same but the thread pitch is different. Can anyone reading this provide info on the difference between the thread on the end of the motor shafts between these makes of dryers ? Also if anyone has attempted to make a blower wheel fit by changing the thread setup perhaps by using a thread insert ? I am always attempting to salvage parts and would like to see if it has been done.
  #28 (permalink)
Old 05-11-2016, 12:21 AM
Junior Member
jasonroy940506 is on a distinguished road
Default
Is there any other diagram to see the thing more about it
  #29 (permalink)
Old 05-11-2016, 03:27 AM
Senior Member
Default
I gave up on that approach and honestly don't remember that unit. That was about 50 dryers back since I buy and sell about one or two a week. Frigidaire and GE are not units I like to work on .
  #30 (permalink)
Old 07-05-2016, 04:19 AM
Junior Member
markdisouza is on a distinguished road
Default Dryer Belt Diagrams
Thanks for this dryer belt diagrams.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag diagrams baradat Washer Repair 4 11-15-2008 04:05 AM
Electrical Diagrams bduprees Refrigerator & Freezer Repair 0 10-01-2008 08:05 AM
Help on schematic diagrams Frank McNeill Oven Repair (including Ranges and Cooktops) 1 07-29-2008 12:12 PM
