Discuss
Idler Arm spring
 in
Dryer Repair
Like others in this forum, I'm attempting to repair a dryer (in a GE Spacemaker Laundry Combo), where the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Idler Arm spring
  #1 (permalink)
Old 11-17-2007, 02:48 PM
JClements JClements is offline
Junior Member
JClements is on a distinguished road
Default Idler Arm spring
Model Number: WSM2400LCB   Brand: GE   Age: 5 - 10 years
Like others in this forum, I'm attempting to repair a dryer (in a GE Spacemaker Laundry Combo), where the end of the Idler/Tension Arm spring has actually broken, resulting in the inability of the arm to maintain tension against the belt. I've ordered a new spring (and a new drive/drum belt), but my question is, where exactly does the end of the spring mount to the dryer body? I can see a hole where the spring loops through the Idler/Tension arm, but the only place I see for the other end of the spring, to attach to the dryer body, is a small hole, almost directly under the spring end, that is drilled into the sheet metal between the upper and lower sections of the unit. I suppose that you could kind of tilt the end of the spring into this hole, but that results in the spring sitting off-kilter at the bottom, and could lead to the spring-end slipping out of the hole. It seems to me, that there should be some sort of bracket where the spring-end could loop through something on the bottom end of it as well. OR, maybe instead of just 1 hole, two small holes, drilled side-by-side, would be more appropriate (as this would enable the curve of the spring-end to loop around something?) Any help in this endeavor would be VERY grateful ... Thanx in advance ... Jeff Clements
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-21-2007, 01:57 PM
Junior Member
Default Idler Arm spring??
Any help with this problem would be very, very appreciated... Thanks.. JeffC.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Question about how to install detergent lid spring. jaholden Dishwasher Repair 1 11-19-2007 10:16 AM
installing idler pulley darberryman Dryer Repair 2 11-08-2007 06:52 AM
Dishwasher door spring wojoe2k7 Dishwasher Repair 3 08-30-2007 08:31 PM
Dryer Idler installation Jeremy Dryer Repair 1 08-04-2007 08:47 PM
Idler Pulley Jeremy Dryer Repair 2 08-03-2007 06:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
