Discuss
changed coils, gas dryer still won't light off
 in
Dryer Repair
The dryer would light off initially, then no more. I read the resistance on the coils, which were outside the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » changed coils, gas dryer still won't light off
  #1 (permalink)
Old 06-28-2011, 04:36 PM
Junior Member
Sailmaker48 is on a distinguished road
Default changed coils, gas dryer still won't light off
Model Number: SDG2606AWW   Brand: Maytag   Age: 5 - 10 years
The dryer would light off initially, then no more. I read the resistance on the coils, which were outside the required range, so replaced them with new coils that tested correctly. Now, the dryer will not light at all. I'm told the gas lighting circuit is wired in series, so if the igniter does light off everything within that circuit is operating as designed. So, if the igniter worked with the older coils and the new coils won't allow it to heat up, does that mean the gas valve is somehow messed up? Or what do you think? Any ideas gleefully received...
Ads By Google
Related Models
Maytag SDG2606AWW Dryer - Gas
Maytag SDG305DAWW Dryer - Gas
Maytag SDG3606AWQ Dryer - Gas
Maytag SDG3606AWW Dryer - Gas
Maytag SDG4000AWW Dryer - Gas
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL Ref - SXS/I&W
Amana SDI22N Ref - SXS/I&W
Amana SDI22N-1 Ref - SXS/I&W
Amana SDI22N-1-A Ref - SXS/I&W
Amana SDI22N-1-AG Ref - SXS/I&W
Amana SDI22N-1-C Ref - SXS/I&W
Amana SDI22N-A Ref - SXS/I&W
Amana SDI22N-AG Ref - SXS/I&W
Amana SDI22N-C Ref - SXS/I&W
Amana SDI22W Ref - SXS/I&W
Amana SDI22W-A Ref - SXS/I&W
Amana SDI22W-AG Ref - SXS/I&W
Amana SDI22W-C Ref - SXS/I&W
  #2 (permalink)
Old 07-01-2011, 12:41 AM
Junior Member
Default
I never located the problem, but I fixed it.
After I put the new coils on and it wouldn't light due to the igniter not heating up, I decided to use jumper wires to bypass each separate part in the circuit. I removed each wire from its spade and then pushed it back on to ensure I wouldn't have any difficulties using the jumpers when the time came.
Just for the hell of it I tried to light it off one more time, and guess what? It worked flawlessly. Now, I know each wire was on the right connector, and I didn't jar any of them during all of this, so it had to be one of them that wasn't making the connection to complete the circuit.
So, before you go off the deep end, remove and replace your wires to ensure a good connection before you make any other decisions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coils on freezer frozen 4 inches of ice above coils Pmathas Refrigerator & Freezer Repair 1 02-22-2011 07:11 PM
dryer won't start changed fuse and hi-limit dryer45 Dryer Repair 0 06-17-2010 04:00 PM
Dryer squeeks already changed bearing tessiepell Dryer Repair 2 04-23-2010 06:56 AM
Toroidal coils,Electric coils manufacturer kelvin_g Heating, Ventilation, and Air Conditioning (HVAC) 0 06-10-2009 10:49 PM
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong Seeking Help Dryer Repair 1 01-12-2009 03:56 AM
