Discuss
Electric Dryer
 in
Dryer Repair
Dryer maintains lowest heat at all heat settings. Very slow dry. Also when door is opened with time remaining the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Dryer
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-28-2011, 03:35 PM
Junior Member
john matz is on a distinguished road
Arrow Electric Dryer
Model Number: 67902790   Brand: Kenmore   Age: More than 10 years
Dryer maintains lowest heat at all heat settings. Very slow dry. Also when door is opened with time remaining the heat doesn't shut off even though the drum ceases to rotate and the fan stops. When the dial is moved to off the heat shuts off. Suspect thermostat and possibly heating element.
Related Models
Maytag 67C DRYER- GAS
Hoover 68
Frigidaire 68-1075 TAPPAN DISHWASHER
Frigidaire 68-1085 TAPPAN 24" BUILT-IN DISHWASHER
Magic Chef 68-2534-40 GAS RANGE
Magic Chef 68-253657 GAS RANGE
Magic Chef 68-2543-80 GAS RANGE
Magic Chef 68-2543-87 GAS RANGE
Magic Chef 68-2558-40 GAS RANGE
Magic Chef 68-255850 GAS RANGE
Magic Chef 68-255857 GAS RANGE
Magic Chef 68-2563-87 GAS RANGE
Magic Chef 68-2593-80 GAS RANGE
Magic Chef 68-2593-81 GAS RANGE
Magic Chef 68-2593-87 GAS RANGE
Hardwick 68-2598 GAS RANGE
Magic Chef 68-454650 ELECTRIC RANGE
Magic Chef 68-454657 ELECTRIC RANGE
Magic Chef 68-4567-40 ELECTRIC RANGE
Magic Chef 68-456750 ELECTRIC RANGE
Magic Chef 68-456751 ELECTRIC RANGE
Magic Chef 68-456757 ELECTRIC RANGE
Magic Chef 68-4585-40 ELECTRIC RANGE
Magic Chef 68-4587-87 ELECTRIC RANGE
Hoover 681
Admiral 684AJ-CKV RANGE- S/C F/S GAS
Admiral 684WJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKVW RANGE- S/C F/S GAS
Admiral 685WJ-CKV RANGE- S/C F/S GAS
Admiral 685WJ-CKVW RANGE- S/C F/S GAS
Admiral 686AJ-EKSVW RANGE- S/C F/S GAS
Admiral 686AJ-TKSVW RANGE- S/C F/S GAS
Admiral 686AK-EKSVW RANGE- S/C F/S GAS
Admiral 686AM-CKSV RANGE- S/C F/S GAS
Admiral 686AM-TKS RANGE- S/C F/S GAS
Admiral 686WJ-EKSVW RANGE- S/C F/S GAS
Admiral 686WJ-TKSVW RANGE- S/C F/S GAS
Admiral 686WK-EKSVW RANGE- S/C F/S GAS
Admiral 686WM-CKSV RANGE- S/C F/S GAS
Admiral 686WM-TKS RANGE- S/C F/S GAS
Admiral 687AF-CKVW RANGE- S/C F/S GAS
Admiral 687AJ-EKZW RANGE- S/C F/S GAS
Admiral 687AJ-TKSAW RANGE- S/C F/S GAS
Admiral 687AK-TKSAW RANGE- S/C F/S GAS
Admiral 687AM-TKSAW RANGE- S/C F/S GAS
Admiral 687WF-CKVW RANGE- S/C F/S GAS
Admiral 687WJ-EKZW RANGE- S/C F/S GAS
Admiral 687WJ-TKSAW RANGE- S/C F/S GAS
Admiral 687WK-TKSAW RANGE- S/C F/S GAS
Admiral 687WM-TKSAW RANGE- S/C F/S GAS
Magic Chef 6892VRA RANGE- S/C S/I ELE
Magic Chef 6892VRV RANGE- S/C S/I ELE
Magic Chef 6892VVA RANGE- S/C S/I ELE
Magic Chef 6892VVV RANGE- S/C S/I ELE
Magic Chef 6892XRA RANGE- S/C S/I ELE
Magic Chef 6892XRS RANGE- S/C S/I ELE
Magic Chef 6892XRW RANGE- S/C S/I ELE
Magic Chef 6892XVA RANGE- S/C S/I ELE
Magic Chef 6892XVB RANGE- S/C S/I ELE
Magic Chef 6892XVS RANGE- S/C S/I ELE
Magic Chef 6892XVW RANGE- S/C S/I ELE
Magic Chef 6893VVD RANGE- S/C S/I ELE
Magic Chef 6893VVV RANGE- S/C S/I ELE
Magic Chef 6893XVB RANGE- S/C S/I ELE
Magic Chef 6895VRA RANGE- S/C S/I ELE
Magic Chef 6895VRV RANGE- S/C S/I ELE
Magic Chef 6896VVD RANGE- S/C S/I ELE
Magic Chef 6896VVV RANGE- S/C S/I ELE
Magic Chef 6896XVB RANGE- S/C S/I ELE
Magic Chef 6898VRA RANGE- S/C S/I ELE
Magic Chef 6898VRV RANGE- S/C S/I ELE
Magic Chef 6898VVA RANGE- S/C S/I ELE
Magic Chef 6898VVD RANGE- S/C S/I ELE
Magic Chef 6898VVV RANGE- S/C S/I ELE
Magic Chef 6898XRA RANGE- S/C S/I ELE
Magic Chef 6898XRB RANGE- S/C S/I ELE
Magic Chef 6898XVB RANGE- S/C S/I ELE
Magic Chef 68HA-3CW RANGE- S/C S/I ELE
Magic Chef 68HA-3CXW RANGE- S/C S/I ELE
Magic Chef 68HA-4TVW RANGE- S/C S/I ELE
Magic Chef 68HA-4TXW RANGE- S/C S/I ELE
Magic Chef 68HA-6TVW RANGE- S/C S/I ELE
Magic Chef 68HK-6TXW RANGE- S/C S/I ELE
Magic Chef 68HN-3CXW RANGE- S/C S/I ELE
Magic Chef 68HN-4TVW RANGE- S/C S/I ELE
Magic Chef 68HN-4TXW RANGE- S/C S/I ELE
Magic Chef 68HN-6TVW RANGE- S/C S/I ELE
Magic Chef 68HN-6TVW-SC RANGE- S/C S/I ELE
Hoover 69
Hoover 691
Whirlpool 6ALBR6245JQ2 AUTOMATIC WASHER
Whirlpool 6ALBR6245MW0 AUTOMATIC WASHER
Whirlpool 6ALBR6245MW3 AUTOMATIC WASHER
Whirlpool 6ALSC8255JQ2 AUTOMATIC WASHER
Whirlpool 6ALSC8255MW0 AUTOMATIC WASHER
Whirlpool 6ALSC8255MW3 AUTOMATIC WASHER
Whirlpool 6ALSQ8000JQ1 AUTOMATIC WASHER
Whirlpool 6ALSQ8000JQ2 AUTOMATIC WASHER
Whirlpool 6ALSQ8000MW0 AUTOMATIC WASHER
Whirlpool 6ALSQ8000MW3 AUTOMATIC WASHER
Whirlpool 6ALSQ8000MW4 AUTOMATIC WASHER
Whirlpool 6ALSR7244JQ1 AUTOMATIC WASHER
Whirlpool 6ALSR7244JQ2 AUTOMATIC WASHER
Whirlpool 6ALSR7244MW0 AUTOMATIC WASHER
Whirlpool 6ALSR7244MW3 AUTOMATIC WASHER
Whirlpool 6ALSR7244MW4 AUTOMATIC WASHER
Whirlpool 6ALSS5233JQ1 AUTOMATIC WASHER
Maytag 6AMTW5405TQ0 AUTOMATIC WASHER
Maytag 6AMTW5455TQ0 AUTOMATIC WASHER
Maytag 6AMTW5455TQ1 AUTOMATIC WASHER
Maytag 6AMTW5555TQ0 AUTOMATIC WASHER
Maytag 6AMTW5555TQ1 AUTOMATIC WASHER
Maytag 6AMTW5855TQ0 AUTOMATIC WASHER
Whirlpool 6AWTW5550XW0 AUTOMATIC WASHER
Whirlpool 6AWTW5700XW0 AUTOMATIC WASHER
Whirlpool 6CA2781XWN0 COMMERCIAL AUTOMATIC WASHER
Whirlpool 6CA2781XWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool 6CAP2762EW0 COMMERCIAL WASHER
Whirlpool 6CAP2782EW0 COMMERCIAL WASHER
  #2 (permalink)
Old 06-28-2011, 05:27 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Looks like your model number is missing 3 digits at the front.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time on a low heat depending how it grounded.
__________________
  #3 (permalink)
Old 06-29-2011, 11:53 AM
Junior Member
Default
Denman,
Thanks for your reply. The first three digits are 110.I think my major concern is that the heating element won't shut off when the dryer door is opened mid cycle.The door can then be closed and if the start button is not depressed to continue the cycle then the heating element continues to heat risking fire. This may be the timer or the on off switch but that exhausts my ideas.
I suppose the thermostat which is a common failure item on these dryers could also be involved. At any rate thanks for your help.
  #4 (permalink)
Old 06-30-2011, 03:29 AM
Senior Expert
APP Volunteer
Default
Replacement parts for KENMORE 11067902790 | AppliancePartsPros.com
I tried to find a wiring diagram and also a actual parts breakdown diagram but had no luck with either.
All I can tell you is that the unit is a Whirlpool.
My original post is still valid.
The unit has 2 centrifugal switches on the motor. They are activated when the motor gets close to operating speed. One of them closes to provide power to the heater so that there is air flow over the heating coils before they turn on.
For some reason your unit's heater is on with no motor rotation and a grounded element is the most common cause.
Here is a good link with basic dryer repair info
http://www.applianceaid.com/dryers.html
__________________
  #5 (permalink)
Old 06-30-2011, 10:53 AM
Junior Member
Default Denman's kind assistance
Dear Denman,
Thanks so much for your assistance. I will check out the element which would be an easy and relatively inexpensive fix.
Sincerely,
John Matz
  #6 (permalink)
Old 07-20-2011, 12:56 PM
Junior Member
Default
Quote:
Originally Posted by john matz View Post
Dear Denman,
Sincerely,
John Matz
Hello Denman,
I changed the heating element and evertything was fixed. Thanks so much for your guidance.
  #7 (permalink)
Old 07-20-2011, 12:59 PM
Junior Member
Red face
Dear Denman,
Thanks so much for your advice. I changed the heating element and all the problems were solved. What a Guy!!
Sincerely,John Matz
  #8 (permalink)
Old 07-20-2011, 01:38 PM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
General Electric DBLR333ET0WW Electric dryer pmkcreations Dryer Repair 0 05-18-2011 05:12 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
how do I get to the dryer belt on a whirlpool electric dryer? jchase Dryer Repair 1 04-16-2011 02:23 PM
Electric Dryer DOTCON Dryer Repair 2 12-04-2008 03:12 PM
