| » Dryer will run but not heat |
Model Number: LER4634JQ1 Brand: Whirlpool Age: 1 - 5 years
Gene,
My Whirlpool dryer runs,but won't heat.I have checked the heating elements(coils),don't see a break in them.I also checked to see if the venting is clogged,no problem there. Any suggestions? Thanks, Allan Related Models |
Check this out,
Video: How to check voltage at cord on a Maytag electric dryer. The video show how to check a maytag dryer, but every electric dryer is this way. |
Allansc,
Also check the thermal fuse for continuity with an ohmmeter. Open=bad, closed=good. The fuse is number 19 on this diagram Inexpensive volt/ohmmeters |
Whirlpool gas dryer LGQ9557KQ0 heats on start up but flame does not come back on after.
I cleared the lint housing, checked the orifice . . . appeared fine. I was checking the parts illustration and saw the internal thermostat bias AP3045874, the T-stat-hi-limit AP3084674, and I read the threads on checking the thermal fuse AP3132867. I'm trying to diagnose or troubleshoot. Would the thermal fuse do that and what do the other 2 items affect? I just measured continuity across my thermal fuse . . . eliminate that as a possiblity. Thanks, Mark Last edited by mark mazurkiewicz : 08-27-2007 at 09:59 AM. Reason: checked thermal fuse |
Make sure you check each (potential) electrical fuse, thermostat, heating coil for continuity. You'll need a multimeter to do this. (Radio Shack -$29). I found a $11 thermostat bad. This did the trick. Give this a try. Make sure the dryer is unplugged when you check for continuity.
Mark, the valve coils are probably bad and only work for the first heat cycle. I'd try replacing the coils.
- Replacement coils for Whirlpool gas dryer - Breakdown diagrams for Model LGQ9557KQ0 |
| Display Modes | |
| Dryer has no heat but runs | Ron L. | Dryer Repair | 7 | 06-15-2009 12:12 PM |
| Dryer won't heat | dwh | Dryer Repair | 1 | 07-30-2007 06:35 PM |
| Dryer runs no heat | Wesley | Dryer Repair | 3 | 07-28-2007 12:23 AM |
| dryer heat | karen | Dryer Repair | 0 | 07-23-2007 01:55 PM |
