Discuss
Dryer keeps blowing electric panel fuse
 in
Dryer Repair
I have a Whirlpool "Imperial Series" dryer.It is a 2001 model, 7 cycle 4 temperatures. Sorry, i
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer keeps blowing electric panel fuse
  #1 (permalink)
Old 11-16-2007, 10:59 PM
birdman birdman is offline
Junior Member
birdman is on a distinguished road
Default Dryer keeps blowing electric panel fuse
Model Number: not known   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool "Imperial Series" dryer.It is a 2001 model, 7 cycle 4 temperatures. Sorry, i do not know the model number.
Was working fine for the past 6 1/2 years until last night.The dryer receptical wiring runs from the home electrical panel (100 amp "fuse" service) to a metal box with a switch and two 30 amp fuses inside. Then it is wired to the recepticle box. The dryer will run for a few minutes tops and then blows the 30 amp fuse that enables the dryer to start and the door light.The other 30 amp fuse which i believe controls the heating element of the dryer does not blow.I had the back cover off the dryer and the blower motor area to clean it out.Exhaust stack is clean.I am lost on this one.My thoughts are I have an electrical short.I ran the dryer with the panel off the back and it did not blow.
Any ideas?
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 11:32 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
the trouble sounds like it,s in the square dee [metal box 2 fuses] if you had an amp probe it should show you it is drawing 22 to 23 amps on the red wire, if so what is happening is when it is running the heat
in the fuse box [metal box]is taking out the 30 amp fuse .So the fix would be to change the fuse box.
__________________
  #3 (permalink)
Old 11-16-2007, 11:53 PM
Junior Member
Default
Thanks for the speedy reply.Unfortunately I do not have anything to test for the amps. When you say replace the fuse box, do you mean the one with the two 30 amp fuses in it?
I took the 30 amp fuse out for the heating element and ran the dryer with only the one 30 amp fuse and it does not blow.When i put the fuse back in it (both fuses now installed) the dryer would run for about a minute and then it blew the start/door light fuse
  #4 (permalink)
Old 11-17-2007, 05:10 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
All indications point to a shorted heating element in the dryer, just pull out the heater housing and remove heating element.
__________________
  #5 (permalink)
Old 11-17-2007, 07:48 AM
Junior Member
Default
Quote:
Thanks for the reply.This being said, are you saying to replace the heating element altogether? If so, is it worth the cost to replace or should i just purchase a new dryer?
  #6 (permalink)
Old 11-17-2007, 08:04 AM
Senior Expert
APP Volunteer
Default
replace the two[ 30 amps fuse] metal box that will solve the problem..
__________________
  #7 (permalink)
Old 11-17-2007, 08:49 AM
Junior Member
Default
Quote:
Thanks Abbie, i will do this.
  #8 (permalink)
Old 11-22-2007, 07:10 PM
Junior Member
Default
Thanks for all the help.I replaced the box switch and my problem was solved! Thanks Abbie for the diagnostic!
  #9 (permalink)
Old 11-23-2008, 01:36 PM
sakleist2 sakleist2 is offline
Junior Member
sakleist2 is on a distinguished road
Default Abbie can you help?
We have the same problem and have bought a new fuse box with a breaker instead of the screw in fuses. How do we wire the box?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermal cut off fuse keeps blowing djnew york Dryer Repair 0 11-12-2007 03:43 PM
Doesn't start - dryer keeps blowing fuse novas Dryer Repair 0 11-08-2007 02:57 PM
How to remove control panel on GEW9868K dryer Speadracer Dryer Repair 4 10-29-2007 03:32 PM
Dryer Control Panel Dead! Corel Dryer Repair 1 08-10-2007 09:47 PM
Taking dryer panel off debmin Dryer Repair 1 07-26-2007 09:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
