| » dryer warm but not hot |
Need a Model Number
Model Number Locator Some units have 2 coils. If yours is one of these perhaps one coil is burned out.
__________________
Model LER4634JQ1 Here is the tech sheet https://www.servicematters.com/docs/...%208528187.pdf Could be just a vent problem Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp.
__________________
If you do not have one I would suggest you purchase a meter.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. First I would check the heating element. Unplug the dryer Remove the wires from both sides of the element Check for resistance. Should be between 7.8 and 11.8 ohms as shown on the wiring diagram. Then check from each side of the element to the frame should be an open circuit (infinite resistance). This checks that you do not have a grounded element. If it is grounded it needs replacing. If you do not have a meter remove the heater and inspect it to see if the element is broken and touching the case. If above OK Take a look at the cycling thermostat. It has an internal heater. I am not sure which set of is the heater. This you can find out using the meter. The contacts should be 0 ohms, the heater should be around 7,000 ohms. If both OK then leave one of the wires off the internal heater, tape it up so it cannot short to anything. Plug the dryer in and give it a try. Now do you have sufficient heat? If yes then the internal heater is on high all the time resulting in low dryer heat. The problem could be with the temp selector always at a low ohms setting (10 ohms)
__________________
| Display Modes | |
| dryer gets warm... not hot | jared palen | Dryer Repair | 1 | 02-25-2010 02:14 PM |
| Dryer won't get warm consistently | asoria | Dryer Repair | 1 | 05-12-2009 03:50 PM |
| Dryer gets warm but not hot | marc045 | Dryer Repair | 2 | 03-15-2009 07:19 PM |
| dryer warm but not hot | baddwarf | Dryer Repair | 4 | 03-09-2009 05:02 AM |
| Dryer won't restart after it is warm | doverdave@juno.com | Dryer Repair | 1 | 05-30-2008 11:43 AM |
