Discuss
Maytag Performa Dryer Just Quit
 in
Dryer Repair
Well I changed the dryer power cord from a 3 prong to a 4 prong...everything worked fine until about the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Performa Dryer Just Quit
  #1 (permalink)
Old 06-25-2011, 03:41 PM
Junior Member
GrantC76 is on a distinguished road
Default Maytag Performa Dryer Just Quit
Model Number: PYE2300AYW   Brand: Maytag   Age: 1 - 5 years
Well I changed the dryer power cord from a 3 prong to a 4 prong...everything worked fine until about the 5th load of drying, the dryer just quit and doesn't come back on.
Related Models
Maytag PYE2300AYW DRYER- ELE
Maytag PYE2300AZW DRYER- ELE
Admiral PYE3200AGW DRYER- ELE
Maytag PYE3200AYW DRYER- ELE
Maytag PYE3200AZW DRYER- ELE
Admiral PYE3300AGW DRYER- ELE
Admiral PYE3300AKW DRYER- ELE
Maytag PYE3300AYW DRYER- ELE
Maytag PYE3300AZW DRYER- ELE
Maytag PYE3360AYW DRYER- ELE
Maytag PYE4500AYQ DRYER- ELE
Maytag PYE4500AYW DRYER- ELE
Maytag PYE4500AZW DRYER- ELE
Maytag PYE4557AYW DRYER- ELE
Maytag PYE4558AYW DRYER- ELE
Maytag PYET244AYW DRYER- ELE
Maytag PYET244AZW DRYER- ELE
Maytag PYET344AYW DRYER- ELE
Maytag PYET344AZW DRYER- ELE
Maytag PYET444AYW DRYER- ELE
Maytag PYET444AZW DRYER- ELE
Maytag PYG1000AWW DRYER- GAS
Maytag PYG2000AWW DRYER- GAS
Maytag PYG2200AWW DRYER- GAS
Admiral PYG2300AGW DRYER- GAS
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
  #2 (permalink)
Old 06-26-2011, 03:13 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts, includes a wiring diagram.
Replacement parts for MAYTAG PYE2300AYW DRYER- ELE | AppliancePartsPros.com
First check that you installed the new power cord correctly.
At the terminal strip red to red, white to white, black to black and then the ground strap from white (usually the center connection on the terminal strip) is disconnected or removed. If just disconnected make sure that it cannot short to the frame. Then the green (earth ground) cord conductor gets attached to the frame.
Check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is OK
Could be that the thermal fuse on the heater (Item 5 in Section 5) has blown.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
If the fuse is OK then check the door switch.
Note: On this unit the timer can be used to check that toy are getting the 120 volts required for the motor. Set the unit to timed dry mid-scale if the timer advances then you have correct power for the motor (Neutral to L1 = 120 volts.) Then odds are it is the fuse or the door switch but could also be the motor itself or the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Dryer isaacls73 Dryer Repair 12 10-01-2012 03:33 PM
dryer quit heating and water quit filling up on Maytag stackable oldrugrat Washer Repair 3 05-17-2011 05:00 AM
Maytag Performa dryer squeaking neustkg Dryer Repair 1 12-05-2008 07:38 AM
Screaming Maytag Performa Dryer CHRIS3560 Dryer Repair 1 11-03-2008 11:58 AM
MAytag Performa Dryer dcheeks30 Dryer Repair 1 10-13-2008 01:05 PM
