Discuss
Dryer does not stop running
 in
Dryer Repair
The dryer turns on with the timer control but will not automatically shut off. No matter what cycle you set
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not stop running
  #1 (permalink)
Old 06-25-2011, 03:11 PM
Junior Member
johngalg is on a distinguished road
Default Dryer does not stop running
Model Number: mde4000ayw   Brand: Maytag   Age: 5 - 10 years
The dryer turns on with the timer control but will not automatically shut off. No matter what cycle you set the dial to, the dial never moves and does not shut off. You can manually turn the dial to off and it will shut off. I just replaced the timer control and nothing has changed even with the new part installed. The dryer heats, shuts off if you open the door, and all else appears to to functioning, but the dial never moves.
Ads By Google
Related Models
Maytag MDE4000AYW Dryer - Ele
Maytag MDE4000AZQ Dryer - Ele
Maytag MDE4000AZW Dryer - Ele
Maytag MDE4057AYA Dryer - Ele
Maytag MDE4057AYQ Dryer - Ele
Maytag MDE4057AYW Dryer - Ele
Maytag MDE4057AYY Dryer - Ele
Frigidaire MDE436RBD0 Frg(v2) / 27 " Electric Dryer
Frigidaire MDE436RBD1 Wwh(v4) / Electric Dryer
Frigidaire MDE436RBD2 Frg(v3) / Electric Dryer
Frigidaire MDE436RBW0 Tap(v10) / 27 " Electric Dryer
Frigidaire MDE436RBW1 Wwh(v5) / Electric Dryer
Frigidaire MDE436RBW2 Frg(v4) / Electric Dryer
Frigidaire MDE436RBWD0 Gib(v14) / 27 " Electric Dryer
Frigidaire MDE436RBWL0 Frg(v2) / 27 " Electric Dryer
Frigidaire MDE436RBWW0 Frg(v1) / 27 " Electric Dryer
Frigidaire MDE436RED0 Frg(v1) / Electric Dryer
Frigidaire MDE436RED1 Frg(v1) / Electric Dryer
Frigidaire MDE436REW0 Frg(v2) / Electric Dryer
Frigidaire MDE436REW1 Frg(v2) / Electric Dryer
Maytag MDE4658AYW Dryer - Ele
Maytag MDE4806AYW Dryer - Ele
Maytag MDE4806AZW Dryer - Ele
Maytag MDE4916AYA Dryer - Ele
Maytag MDE4916AYW Dryer - Ele
Maytag MDE4916AZW Dryer - Ele
Maytag MDE5000AYQ Dryer - Ele
Maytag MDE5000AYW Dryer - Ele
Maytag MDE5000AZW Dryer - Ele
Maytag MDE508DAYK Dryer - Ele
Maytag MDE508DAYW Dryer - Ele
Frigidaire MDE546RED0 Frg(v1) / Electric Dryer
Frigidaire MDE546RED1 Frg(v1) / Electric Dryer
Frigidaire MDE546RES0 Frg(v2) / Electric Dryer
Frigidaire MDE546RES1 Frg(v2) / Electric Dryer
Frigidaire MDE546RET0 Frg(v3) / Electric Dryer
Frigidaire MDE546REW0 Frg(v4) / Electric Dryer
Frigidaire MDE546REW1 Frg(v3) / Electric Dryer
Maytag MDE5500AYQ Dryer - Ele
Maytag MDE5500AYW Dryer - Ele
Maytag MDE5500AZQ Dryer - Ele
Maytag MDE5500AZW Dryer - Ele
Maytag MDE5806AYK Dryer - Ele
Maytag MDE5806AYW Dryer - Ele
Maytag MDE5806AZK Dryer - Ele
Maytag MDE5806AZW Dryer - Ele
Maytag MDE5960AYW Dryer - Ele
Maytag MDE6000AUW Dryer - Ele
Maytag MDE6000AYQ Dryer - Ele
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
  #2 (permalink)
Old 06-25-2011, 08:10 PM
Junior Member
leosar is on a distinguished road
Default
Quote:
did you check if the timer motor is energised? could be bad contact or wire broken on the timer
  #3 (permalink)
Old 06-26-2011, 02:57 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Wiring information replacement parts for MAYTAG MDE4000AYW DRYER- ELE | AppliancePartsPros.com
By "timer control", I am assuming you mean the Dryness Control Board.
I am also assuming that you have tried both timed dry and auto cycles.
Only way to be sure is to measure the voltage across the timer motor. If you get 120 volts and the timer does not advance then it is toast.
Be careful there is 240 volts at the timer and this is lethal!!!
Unplug the unit, place it mid scale timed dry and check if contact set 2 is closed.
If not then the timer is toast.
If there is no 120 volts in timed dry and timer contacts 2 are closed, then odds are that the replacement board is defective.
__________________
  #4 (permalink)
Old 06-26-2011, 06:24 AM
Junior Member
Default
Quote:
I have continuity on grey and yellow with the timer set midway on the timed dry cycle
  #5 (permalink)
Old 06-26-2011, 07:27 AM
Senior Expert
APP Volunteer
Default
Contact set 2 that supplies power to the Dry Control board should be yellow and orange according to the wiring diagram.
Also always disconnect one side of any device/contact set when measuring for continuity/resistance. this prevents you from reading an alternate/parallel circuit path.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't stop running rudyworks Dryer Repair 0 09-13-2010 02:55 PM
Dryer will not stop running Katie D. Dryer Repair 1 03-14-2010 05:24 PM
dryer won't stop running jasond Dryer Repair 4 09-27-2009 04:19 AM
dryer won't stop running! raycharn Dryer Repair 2 11-25-2008 06:37 AM
Dryer won't stop running manderson Dryer Repair 0 08-04-2008 06:46 AM
