| » Dryer heats but not when clothes are in it |
Model Number: 80-Series Brand: Kenmore Age: 5 - 10 years
Kenmore Dryer: heats when empty, but when clothes are put in, even a small amount, it does not heat. I took off the back cover & removed a lot of lint build up, thought I had it solved, but still the same story. The fan blades spin in the blower...what part do I need to replace? Please help! Thanks!
A Model Number might help
You cleaned out the dryer, did you also clean and check your vent system? You say the blower wheel spins, are you saying they turn without turning the motor? Is the below correct: With clothes in it the drum turns but you get no heat? When you first start a cycle with clothes, does it start to heat then the heat turns off and the drum continues to rotate? VENT CHECK Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
__________________
Model #110.72822101 Kenmore Gas Dryer
Vent system is clear, louvers on outside open, warm air exiting Blower wheel spins on its own. I do notice that while it is warm inside the dryer when running for a short time, it is not HOT. Could it be the igniter at its end, or is that a case of it either working or not working at all? |
| Display Modes | |
| GE Dryer Heats Clothes but Doesnt Dry | michaelb87 | Dryer Repair | 1 | 02-17-2010 02:43 PM |
| dryer heats but not enough to dry the clothes | winkk017 | Dryer Repair | 3 | 11-16-2009 06:28 PM |
| RCA Dryer Heats Up, Clothes Still Damp | patmac | Dryer Repair | 6 | 10-18-2009 06:49 AM |
| My dryer only heats up when dry clothes are put in. | bravosoldier | Dryer Repair | 1 | 10-04-2009 09:26 PM |
| Maytag dryer turns and heats but clothes not dry | ldhaynes | Dryer Repair | 1 | 02-16-2009 10:12 AM |
