Discuss
Thermal fuse & thermostats
 in
Dryer Repair
The thermal fuse has blown. I suspect it was because of a faulty thermostat. I have checked the thermal cut
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Thermal fuse & thermostats
  #1 (permalink)
Old 11-16-2007, 12:41 PM
john hicks john hicks is offline
Junior Member
john hicks is on a distinguished road
Default Thermal fuse & thermostats
Model Number: REL4636BW!   Brand: Roper   Age: 5 - 10 years
The thermal fuse has blown. I suspect it was because of a faulty thermostat. I have checked the thermal cut off and high limit thermostats at room temperature and they have continuity.
The dryer cycling thermostat has continuity between the top and bottom terminals, but shows some resistance between the 2 side terminals.
The vent system is unobstructed.
What most likely caused my thermal fuse to blow?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 02:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The manufacturer advised to replace the cycling thermostat in case of the blown thermal fuse because of the faulty temperature parameters not electrical.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model REL4636BW0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 07:52 PM
bypass thermal fuse? markus Dryer Repair 3 11-14-2007 01:14 PM
thermal cut off fuse keeps blowing djnew york Dryer Repair 0 11-12-2007 03:43 PM
Thermal fuse location Dbowls Dryer Repair 4 08-29-2007 03:37 PM
What is the difference between thermostats Ken r Dryer Repair 4 08-22-2007 06:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
