Discuss
Dryer initially starts, stops after 1 second
 in
Dryer Repair
Electric dryer, very little use. Will start to tumble every time, but stops after 1 second. KEYS977EQ model.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer initially starts, stops after 1 second
  #1 (permalink)
Old 06-23-2011, 03:32 PM
Junior Member
diy31 is on a distinguished road
Default Dryer initially starts, stops after 1 second
Brand: Kitchen Aid   Age: More than 10 years
  #2 (permalink)
Old 06-25-2011, 03:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL KEYS977EQ0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the tech sheet
Does it do this in both timed and auto cycles?
If only in auto then your moisture sensor may need cleaning.
Can you restart it right away or do you have to wait several minutes.
If you have to wait then odds are that the motor is overheating for some reason. It then trips it's internal thermal protect and you have to wait for the motor to cool down so the protect resets.
__________________
  #3 (permalink)
Old 06-25-2011, 07:07 AM
Junior Member
Default
Denman
Thanks for your attention to my problem. I just went down and checked the unit and it makes no difference whether in Auto or Timed modes - the unit begins to tumble but stops literally after just 1 second or so.
Further, it will do this as many times as you like, in succession, without any waiting period in between.
Does this help narrow it down?
  #4 (permalink)
Old 06-25-2011, 12:27 PM
Senior Expert
APP Volunteer
Default
It does tell us that the motor is not overheating.
It sounds like the control board is no good.
The motor runs so the motor relay is OK but for some reason the control board is niot holding the relay closed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer starts / stops J_Fitz_1 Dryer Repair 3 04-11-2010 08:12 AM
Kenmore Elite H3 - Heats up initially but then stops heating. anonymouscuban Dryer Repair 2 01-07-2010 07:52 PM
Heats up initially, then stops ... Avenger9 Dryer Repair 1 07-17-2009 04:50 PM
Dryer starts to dry then stops Bryan507 Dryer Repair 1 06-20-2008 04:18 PM
Dryer starts then stops Redwings19 Dryer Repair 0 09-20-2007 09:09 AM
