The dryer runs fine but no hot air. Checked lint and that's all clear. What should Icheck next?
Originally Posted by: Betsy123 The dryer runs fine but no hot air. Checked lint and that's all clear. What should Icheck next? Betsy, You should check the ignition process next. On the lower area of the front panel, there is a 1X1 inch square plastic cover that is removable. Carefully remove the cover, start the dryer on a high heat setting, and use the "peep"hole for observing the process: Start the dryer, you should hear a click noise. You should see the igniter start to glow red. After a few seconds, you should hear another click. The igniter glow, should start to fade and the gas should be released and the gas ignite, and flame appear. No glow would indicate a broken igniter, bad flame sensor switch or open thermostat/wire. Glow never fades, bad flame sensor switch. Igniter glows, then fades, but no flame, indicates a bad set of gas valve coils. Let us know what does or does not occurr, and we'll go from there. :) :) :)
Thanks for the reply Joe. The dryer clicks on, I see the glow, the flame comes on sometimes but it just goes out. If I shut the dryer off and restart, same thing. Sometimes it comes on, sometimes it doesn't.
Your coils are failing and need to be replaced ... Here is a video and the part you will need to fix your dryer YouTube - ‪Dryer Repair Help Video "Repairing Heating Problems"‬‏
Appliance Parts > Dryer Parts > Dryer Igniters and Gas Valve Coils
div#boxclose{position:absolute; margin-top:88px; margin-left:325px; z-index:100;}div#rounded{margin-top:100px; margin-left:100px; width:240px; background: #f8e45a; position:absolute; opacity:.9; filter: alpha(opacity = 90);}b.rtop, b.rbottom{display:block;background: #FFF}b.rtop b, b.rbottom b{display:block;height: 1px;overflow: hidden; background: #f8e45a}b.r1{margin: 0 5px}b.r2{margin: 0 3px}b.r3{margin: 0 2px}b.rtop b.r4, b.rbottom b.r4{margin: 0 1px;height: 2px} [/URL]Different views available: Coil Kit for Dryer Gas Valve (2 Coils, New Style) - Made by Whirlpool. This popular, newer style solenoid coil kit fits all dryers with two-coil gas valve. Brands include Whirlpool, Kenmore, Maytag, Admiral, Crosley, Frigidaire, Estate, Amana, Kitchen Aid, GE, Hotpoint, Roper, White Westinghouse, Sears and others.
Part Number: AP3094251 Made by Whirlpool Original Whirlpool Part
Whirlpool brands include Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, Admiral, Norge, Roper, and others. Whirlpool also makes various appliance models for Sears / Kenmore.
Sale Price: $15.95 Reg. retail: $21.80 You Save: $5.85 In Stock Order now and it will ship Today
Read more: Part Details - WHIRLPOOL Coil Kit for Dryer Gas Valve (2 Coils, New Style), part number: AP3094251 [url=http://www.appliancepartspros.com]Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
Originally Posted by: Betsy123 Thanks for the reply Joe. The dryer clicks on, I see the glow, the flame comes on sometimes but it just goes out. If I shut the dryer off and restart, same thing. Sometimes it comes on, sometimes it doesn't. Betsy, I have a feeling that it's a weak set of coils, like Gabe, stated. One way to verify it, would be the same process, start the dryer, etc. Let the dryer run/heat for 20 minutes, Then do the observation, again. It can take a while, when the weak coil issue begins, the longer the coils are energized, the weaker the circuit gets, and should fail. Another check, is to start the dryer and open the dryer door within 20 seconds, you'll need to do this several times(3 to 5 times) then start th dryer and do the observation again. :) :) :)
