Discuss
Amana Timer wont advance??
 in
Dryer Repair
I just finished replacing the drum rollers on this dryer and after I got it all put back together, the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Timer wont advance??
  #1 (permalink)
Old 03-05-2009, 08:04 PM
Junior Member
jaredegley is on a distinguished road
Default Amana Timer wont advance??
Model Number: LGD20AW   Brand: Amana   Age: More than 10 years
I just finished replacing the drum rollers on this dryer and after I got it all put back together, the timer will no longer advance. Before the repair it didn't advance in the auto dry mode, but the timed dry worked fine. Now it won't advance in any mode. Everything else works fine. I'm 100% certain the wires are connected correctly. Are those timers delicate enough to get damage while repairing the dryer? I was very careful with all the parts and I don't want to shell out $90 for a timer if that isn't the problem.
Ads By Google
Related Models
Amana LGD20AW Dryer - Gas
Amana LGD251 Dryer - Gas
Amana LGD312 Dryer - Gas
Amana LGD32AW Dryer - Gas
Amana LGD451 Dryer - Gas
Amana LGD512 Dryer - Gas
Amana LGD57AW Dryer - Gas
Amana LGD65AW Dryer - Gas
Amana LGD851 Dryer - Gas
Amana LGD912 Dryer - Gas
Amana LGD951 Washer - Top Loading
Whirlpool LGE9848BQ1
Whirlpool LGE9848BQ2
Whirlpool LGE9848BZ1
Whirlpool LGE9848BZ2
Whirlpool LGL7646EQ0
Whirlpool LGL8858DQ0
Whirlpool LGL8858DZ0
Whirlpool LGL8858EQ0
Whirlpool LGL8858EQ1
Whirlpool LGL8858EQ2
Whirlpool LGL8858EQ3
Amana LGM439L Dryer - Gas
Amana LGM439W Dryer - Gas
Amana LGM449L Dryer - Gas
Amana LGM449W Dryer - Gas
Amana LGM549L Dryer - Gas
Amana LGM549W Dryer - Gas
Amana LGM849W Dryer - Gas
Whirlpool LGN1000HQ0
Whirlpool LGN1000HQ1
Whirlpool LGN1000PQ0 29"gas Dryer
Whirlpool LGN1000PQ1 29"gas Dryer
Whirlpool LGN2000JQ0
Whirlpool LGN2000JQ1
Whirlpool LGN2000JQ2
Whirlpool LGN2000JQ3
Whirlpool LGN2000JT0
Whirlpool LGN2000JT1
Whirlpool LGN2000JT2
Whirlpool LGN2000JT3
Whirlpool LGN2000KQ0
Whirlpool LGN2000KQ1 29"gas Dryer
Whirlpool LGN2000KQ2 29"gas Dryer
Whirlpool LGN2000KT0
Whirlpool LGN2000KT1 29"gas Dryer
Whirlpool LGN2000LG0
Whirlpool LGN2000LG1 29"gas Dryer
Whirlpool LGN2000LW0
Whirlpool LGN2000LW1 29"gas Dryer
Whirlpool LGN2000PG0 29"gas Dryer
Whirlpool LGN2000PG1 29"gas Dryer
Whirlpool LGN2000PW0 29"gas Dryer
Whirlpool LGN2000PW1 29"gas Dryer
Whirlpool LGN3434AW0
Whirlpool LGN3624BN0
Whirlpool LGN3624BN1
Whirlpool LGN3624BN2
Whirlpool LGN3624BW0
Whirlpool LGN3624BW1
Whirlpool LGN3624BW2
Whirlpool LGN3634DW0
Whirlpool LGN3634DW1
Whirlpool LGP6646AN0
Whirlpool LGP6646AN1
Whirlpool LGP6646AN2
Whirlpool LGP6646AW0
Whirlpool LGP6646AW1
Whirlpool LGP6646AW2
Whirlpool LGP6848AN0
Whirlpool LGP6848AN1
Whirlpool LGP6848AW0
Whirlpool LGP6848AW1
Whirlpool LGP7858AN0
Whirlpool LGP7858AN2
Whirlpool LGP7858AQ2
Whirlpool LGP7858AW0
Whirlpool LGP7858AW2
Whirlpool LGP7858AZ2
Frigidaire LGQ1442ES0 Frigidaire/dryer
Frigidaire LGQ2152EE0 Frigidaire/dryer
Frigidaire LGQ2152ES0 Frigidaire/dryer
Frigidaire LGQ332DS0 Frigidaire/dryer
Frigidaire LGQ6000ES0 Frigidaire/dryer
Frigidaire LGQ6000ES1 Frigidaire/dryer
Frigidaire LGQ6000ES2 Frigidaire/dryer
Frigidaire LGQ642DS0 Frigidaire/dryer
Frigidaire LGQ7000EG0 Frigidaire/dryer
Frigidaire LGQ7000ES0 Frigidaire/dryer
Frigidaire LGQ7000ES1 Frigidaire/dryer
Frigidaire LGQ7000ES2 Frigidaire/dryer
Whirlpool LGQ7030KQ0
Whirlpool LGQ7030KQ1
Whirlpool LGQ7030KQ2 29"gas Dryer
Whirlpool LGQ8000HQ0
Whirlpool LGQ8000HQ1
Whirlpool LGQ8000JQ1
Whirlpool LGQ8000JQ2
Whirlpool LGQ8000JQ3
Whirlpool LGQ8000JQ4 29"gas Dryer
Whirlpool LGQ8000JQ5 29"gas Dryer
Whirlpool LGQ8100KQ0
Whirlpool LGQ8100KQ1
Whirlpool LGQ8100KT0
Whirlpool LGQ8100KT1
Whirlpool LGQ8611LG0
Whirlpool LGQ8611LG1 27"gas Dryer
Whirlpool LGQ8611LW0
Whirlpool LGQ8611LW1 27"gas Dryer
Whirlpool LGQ8611PG0 27"gas Dryer
Whirlpool LGQ8611PG1 27"gas Dryer
Whirlpool LGQ8611PG2 27"gas Dryer
Whirlpool LGQ8611PG3 27"gas Dryer
  #2 (permalink)
Old 03-06-2009, 07:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove one of the timer motor wires and check the motor for continuity. If it's open the timer has to be replaced.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-12-2009, 11:47 AM
Junior Member
Default
Gene,
I just bought a timer from app to replace the old one because it hasn't worked in the auto-dry mode for years and that didn't fix the problem. The only thing left to replace is the cycling thermostat on the blower isn't it? Shouldn't the timer still advance in timed dry if I select no heat even if the cycling thermostat is bad?
  #4 (permalink)
Old 03-12-2009, 03:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Did you do this test?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
MAYTAG GAS DRYER, timer wont advance babewk Dryer Repair 1 11-12-2009 12:51 PM
Amana Dryer dries slowly, and More/Less Dry Timer does not advance dtshenoy Dryer Repair 1 04-13-2009 07:36 AM
Dryer timer wont advance in automatic mode player4 Dryer Repair 1 02-07-2009 03:24 AM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
