Discuss
Testing a Cycling thermostat
 in
Dryer Repair
I have a dryer that no longer puts out heat. I've tested the thermal fuse for continuity with the wires
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Testing a Cycling thermostat
  #1 (permalink)
Old 06-20-2011, 07:03 PM
Junior Member
MrFunnyMan is on a distinguished road
Default Testing a Cycling thermostat
Model Number: 96282100   Brand: Kenmore   Age: More than 10 years
I have a dryer that no longer puts out heat. I've tested the thermal fuse for continuity with the wires disconnected and it has continuity. I've done the same for the heating element and it checks out fine. I'm trying to test the Cycling thermostat. I have it disconnected, and the outside terminals have continuity, but the inside terminals do not. Is this normal?
David
Related Models
Amana 968.000 RANGE- S/C S/I DDRAFT GAS
Amana 968.010 RANGE- S/C S/I DDRAFT GAS
Admiral 968AF-C RANGE- S/C D/I ELE
Admiral 968AH-CHZW RANGE- S/C D/I ELE
Admiral 968WF-C RANGE- S/C D/I ELE
Admiral 968WH-CHZW RANGE- S/C D/I ELE
Amana 969.000 RANGE- S/C S/I DDRAFT GAS
Amana 969.001 RANGE- S/C S/I DDRAFT GAS
Amana 969.002 RANGE- S/C S/I DDRAFT GAS
Amana 969.003 RANGE- S/C S/I DDRAFT GAS
Magic Chef 96F-4CLX-19 WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CLW WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CW WALLOVEN- STD ELE
Magic Chef 96FA-4CX WALLOVEN- STD ELE
Magic Chef 96FN-4CLW WALLOVEN- CONT CLEAN ELE
Magic Chef 96FN-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 96FN-4CW WALLOVEN- STD ELE
Magic Chef 96FN-4CX WALLOVEN- STD ELE
Kenmore 970-445341 RANGE (CANADIAN)
Kenmore 970-598421 ELECTRIC RANGE
Kenmore 970-C40032-00 WASHER
Kenmore 970-C40042-00 WASHER
Kenmore 970-C40052-00 WASHER
Kenmore 970-C90052-00 DRYER
Kenmore 970-C90702-00 LAUNDRY CENTER
Kenmore 970-C90802-00 DRYER
Kenmore 970-C90862-00 LAUNDRY CENTER
Kenmore 970-C98902-00 LAUNDRY CENTER
Amana 970.000 RANGE- S/C S/I DDRAFT GAS
Amana 970.001 RANGE- S/C S/I DDRAFT GAS
Amana 970.002 RANGE- S/C S/I DDRAFT GAS
Kenmore 9703871220 SEARS-CANADA WASHER
Kenmore 9703880220 SEARS-CANADA WASHER
Kenmore 970C8003200 DRYER
Kenmore 970C8004200 DRYER
Kenmore 970C8005200 DRYER
Kenmore 970C9003200 DRYER
Kenmore 970C9004200 DRYER
Amana 975.000 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 97F-4EXWM9 WALLOVEN- S/C MWAVE ELE
Magic Chef 97F-4EXWW WALLOVEN- S/C ELE
Magic Chef 97FN-4EVWW WALLOVEN- S/C ELE
Magic Chef 97FN-4EXWW WALLOVEN- S/C ELE
Frigidaire 98-1348-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1348-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1348-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1668-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1668-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-03 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-2188-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-2188-00-03 Tap(v1) / Upright Freezer
Amana 980.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 980.001 RANGE- S/C S/I DDRAFT GAS
Amana 980.002 RANGE- S/C S/I DDRAFT GAS
Amana 980.003 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 9814VPV WALLOVEN- S/C ELE
Magic Chef 9814XPB WALLOVEN- S/C ELE
Magic Chef 9815VUV WALLOVEN- S/C ELE
Magic Chef 9815XUB WALLOVEN- S/C ELE
Magic Chef 9824VPV WALLOVEN- S/C ELE
Magic Chef 9824XPB WALLOVEN- S/C ELE
Magic Chef 9825VUV WALLOVEN- S/C ELE
Magic Chef 9825XUB WALLOVEN- S/C ELE
Magic Chef 9834XPB WALLOVEN- S/C MWAVE ELE
Magic Chef 9835VVV WALLOVEN- S/C MWAVE ELE
Magic Chef 9835XUB WALLOVEN- S/C MWAVE ELE
Magic Chef 9835XVB WALLOVEN- S/C MWAVE ELE
Magic Chef 9844VPV WALLOVEN- S/C ELE
Magic Chef 9844XPB WALLOVEN- S/C ELE
Magic Chef 9845VUV WALLOVEN- S/C ELE
Magic Chef 9845VVV WALLOVEN- S/C ELE
Magic Chef 9845XUB WALLOVEN- S/C ELE
Magic Chef 9845XVB WALLOVEN- S/C ELE
Magic Chef 9850 MICROWAVE OVEN
Magic Chef 9854VPV WALLOVEN- S/C ELE
Magic Chef 9854XPB WALLOVEN- S/C ELE
Magic Chef 9855VUV WALLOVEN- S/C ELE
Magic Chef 9855VVV WALLOVEN- S/C ELE
Magic Chef 9855XUB WALLOVEN- S/C ELE
Magic Chef 9855XVB WALLOVEN- S/C ELE
Magic Chef 9864VPV WALLOVEN- S/C MWAVE ELE
Magic Chef 9864XPB WALLOVEN- S/C MWAVE ELE
Magic Chef 9865VUV WALLOVEN- S/C MWAVE ELE
Magic Chef 9865XUB WALLOVEN- S/C MWAVE ELE
Magic Chef 9875VRV WALLOVEN- S/C ELE
Magic Chef 9875VVV WALLOVEN- S/C ELE
Magic Chef 9875VYV WALLOVEN- S/C ELE
Magic Chef 9875XRB WALLOVEN- S/C ELE
Magic Chef 9875XVB WALLOVEN- S/C ELE
Magic Chef 9875XYB WALLOVEN- S/C ELE
Magic Chef 9876VVV WALLOVEN- S/C ELE
Magic Chef 9876XVB WALLOVEN- S/C ELE
Amana 988.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 988.010 MWAVE - FAMILY SIZE (60 HZ)
Amana 989.000 RANGE- S/C S/I DDRAFT GAS
Amana 989.001 RANGE- S/C S/I DDRAFT GAS
Amana 989.002 RANGE- S/C S/I DDRAFT GAS
Amana 989.003 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 9895VRV WALLOVEN- S/C MWAVE ELE
Magic Chef 9895XRB WALLOVEN- S/C MWAVE ELE
Magic Chef 98FA-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 98FA-4CLX-19 WALLOVEN- CONT CLEAN ELE
Magic Chef 98FA-4CW WALLOVEN- STD ELE
Magic Chef 98FA-4CX WALLOVEN- STD ELE
Magic Chef 98FN-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 98FN-4CLX-19 WALLOVEN- CONT CLEAN ELE
Magic Chef 98FN-4CW WALLOVEN- STD ELE
Magic Chef 98FN-4CX WALLOVEN- STD ELE
Frigidaire 99-0828-00-03 Tap(v2) / Chest Freezer
Frigidaire 99-0828-23-00 Tap(v1)
Frigidaire 99-0828-23-01 Tap(v2)
Frigidaire 99-0828-23-02 Tap(v3)
Frigidaire 99-0828-23-03 Tap(v1) / Chest Freezer
Frigidaire 99-1348-00-03 Tap(v1) / Upright Freezer
Tappan 99-1348-003 CHEST FREEZER - 5995209318
Frigidaire 99-1648-00-00 Tap(v1) / Chest Freezer
  #2 (permalink)
Old 06-20-2011, 07:54 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Cannot find any info on the model number.
Looks like it is missing the first 3 digits which is the manufacturer number.
If the outer two connectors had the larger wires on them then these are the contacts and it measures OK.
The inner two are then the internal heater and can be in the 5,000 to 20,000 ohm range.
You may be using too low of a meter scale.
In any case a blown internal heater will not cause no heat.
Have you checked the power?
The motor and timer usually use 120 volts but the heater requires the full 240.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 06-20-2011, 11:34 PM
Junior Member
dean5rios is on a distinguished road
Default
Having one question that Where is the cycling thermostat located on Maytag Drye?
courier services
  #4 (permalink)
Old 06-21-2011, 02:02 AM
Senior Expert
APP Volunteer
Default
dean5rios
Please start your own thread using "Post New Topic".
Adding to another persons thread will just confuse things.
Be sure to add the model number to your post.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New cycling thermostat Jose1949 Dryer Repair 3 05-27-2011 06:30 AM
Replace high limit thermostat a or cycling thermostat along with the thermal fuse? BrassMonkey Dryer Repair 1 11-15-2010 06:23 PM
Cycling/operating Thermostat Gas Dryer MARCSFIX Dryer Repair 1 08-01-2010 10:40 PM
Amana Cycling Thermostat Blind Squirrels Dryer Repair 10 07-01-2009 05:25 PM
Fridge Thermostat Testing Tony.C Refrigerator & Freezer Repair 2 08-07-2007 12:31 PM
