Discuss
pappyky
 in
Dryer Repair
Will not start.....place time in any position and can hear timer running, but when I press the start button nothing
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » pappyky
  #1 (permalink)
Old 06-20-2011, 06:44 PM
Junior Member
pappyky is on a distinguished road
Smile pappyky
Model Number: LEC8858EQ0   Brand: Whirlpool   Age: 5 - 10 years
Will not start.....place time in any position and can hear timer running, but when I press the start button nothing happens....was working just fine the previous load.....could it be that switch/pts relay ? WQould like advice before blindly ordering parts . Thanks
Ads By Google
Related Models
Whirlpool LEC8858EQ0
Whirlpool LEC8858EQ1
Whirlpool LEC8858EQ2
Whirlpool LEC8858EZ0
Whirlpool LEC8858EZ1
Whirlpool LEC8858EZ2
Whirlpool LEC9000PW0 29" Electric Dryer
Whirlpool LEC9000PW1 29" Electric Dryer
Amana LEC90AW Dryer - Ele
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Amana LED20AW Dryer - Ele
Amana LED250 Dryer - Ele
Amana LED302 Washer - Top Loading
Amana LED32AW Dryer - Ele
Amana LED450 Dryer - Ele
Amana LED502 Dryer - Ele
Amana LED57AW Dryer - Ele
Amana LED65AW Dryer - Ele
Amana LED850 Dryer - Ele
Amana LED902 Dryer - Ele
Amana LED950 Dryer - Ele
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0
Whirlpool LEE9848BQ1
Whirlpool LEE9848BQ2
Whirlpool LEE9848BZ0
Whirlpool LEE9848BZ1
Whirlpool LEE9848BZ2
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0
Whirlpool LEL7646EQ1
Whirlpool LEL8858DQ0
Whirlpool LEL8858DZ0
Whirlpool LEL8858EQ0
Whirlpool LEL8858EQ1
Whirlpool LEL8858EQ2
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
General Electric LEM045J02 Counter top microwave
General Electric LEM045J03 Counter top microwave
General Electric LEM065H01 Electric range
General Electric LEM085H01 Electric range
Amana LEM427L Dryer - Ele
Amana LEM427W Dryer - Ele
Amana LEM437L Dryer - Ele
Amana LEM437W Dryer - Ele
Amana LEM447L Dryer - Ele
Amana LEM447W Dryer - Ele
Amana LEM547L Dryer - Ele
Amana LEM547W Dryer - Ele
Amana LEM847W Dryer - Ele
Whirlpool LEN1000HQ0
Whirlpool LEN1000HQ1
Whirlpool LEN1000PQ0 29"electric Dryer
Whirlpool LEN1000PQ1 29"electric Dryer
Whirlpool LEN2000JQ0
Whirlpool LEN2000JQ1
Whirlpool LEN2000JQ2
Whirlpool LEN2000JT0
Whirlpool LEN2000JT1
Whirlpool LEN2000JT2
Whirlpool LEN2000KQ0
Whirlpool LEN2000KQ1 29"electric Dryer
Whirlpool LEN2000KQ2 29"electric Dryer
Whirlpool LEN2000KT0
Whirlpool LEN2000KT1 29"electric Dryer
Whirlpool LEN2000LG0
Whirlpool LEN2000LG1 29"electric Dryer
Whirlpool LEN2000LW0
Whirlpool LEN2000LW1 29"electric Dryer
Whirlpool LEN2000PG0 29"electric Dryer
Whirlpool LEN2000PG1 29"electric Dryer
Whirlpool LEN2000PW0 29"electric Dryer
Whirlpool LEN2000PW1 29"electric Dryer
Whirlpool LEN3434AW0
Whirlpool LEN3624BN0
Whirlpool LEN3624BN1
Whirlpool LEN3624BN2
Whirlpool LEN3624BW0
Whirlpool LEN3624BW1
Whirlpool LEN3624BW2
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
  #2 (permalink)
Old 06-21-2011, 05:55 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LEC8858EQ0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
At the top of my list would be the thermal fuse (Item 7 in Section 3)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
