| » Dryer Heats But will not shut off |
A model number may help others help you.
It does sound like a grounded heating coil. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time.
__________________
| Display Modes | |
| Dryer will not shut off but heats ok | twilliams0204 | Dryer Repair | 2 | 12-17-2010 04:37 AM |
| Dryer heats but will not shut off | gshafer | Dryer Repair | 2 | 09-08-2010 05:51 AM |
| Dryer won't shut off--but only heats sometimes! | laroz2003 | Dryer Repair | 3 | 04-05-2010 09:29 PM |
| Dryer heats in auto but wont shut off | CSH12H | Dryer Repair | 1 | 10-16-2009 11:51 AM |
| GE electric dryer runs, heats, won't shut off | carpenter | Dishwasher Repair | 2 | 04-29-2008 09:32 AM |
