Discuss
Motor grommets compressed
 in
Dryer Repair
1994 Admiral, Designer Series Gas Dryer. Model LNC8744A17, Rev B., Serial 49J410907. Motor mounts on both ends (blower case &
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor grommets compressed
  #1 (permalink)
Old 03-04-2009, 04:59 PM
Junior Member
joe1999 is on a distinguished road
Question Motor grommets compressed
Model Number: LNC8744A17   Brand: Admiral   Age: More than 10 years
Motor mounts on both ends (blower case & belt drive) have been compressed from the loading of the tension pulley over time. Motor runs great with little shaft end thrust and no side play. Misalignment of motor shaft caused squirrel cage of blower section to rub into the pastic blower case which loaded the squirrrel cage connection to the shaft.
Are the rubber motor mounts replacable? If so, what does it take to do it?
Ads By Google
Related Models
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
  #2 (permalink)
Old 03-05-2009, 12:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by joe1999 View Post
...Are the rubber motor mounts replaceable?...
Unfortunately it is a part of the motor.
The model number you posted does not come up. Verify and repost it if you need the part number for the motor.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-06-2009, 06:19 AM
Junior Member
Default Thanks Gene ...
...I was afraid that was the case. Too bad since motor runs fine.
Model number is actual full model number. I have the motor number on file.
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy Whirlpool Dishwasher: Replace just motor or whole pump&motor mdion Dishwasher Repair 7 02-28-2011 01:31 PM
Where does the motor spring attach to on the motor side? mjeakman Washer Repair 3 01-15-2010 04:21 PM
Leak at back of motor/motor just hums rgtrev Dishwasher Repair 0 09-21-2009 02:17 PM
Frontload Washer - motor or motor control problem? chris-clarke Washer Repair 3 04-06-2009 10:12 AM
Repair Freezer Shelf Grommets jratliff Refrigerator & Freezer Repair 0 02-12-2009 11:16 AM
