| » Maytag Dryer Noise |
Model Number: MDE9306AYW Brand: Maytag Age: 5 - 10 years
I have read several other posts on various sites about similar noise in Maytag Dryers. Ours varies from very high pitched squeel to annoying loud noises when the dryer is running. We have replaced the drum rollers (not the shafts), the front teflon bearings, the idler arm and bearing and the belt. We ran the motor when dryer disassembled and it did not appear to be making any unusual noises by itself. We removed the blower fan and cleaned out that area completely and noted the fan hole was a proper D shape. The felt seems in good condition. After carefully reassembling everything, it still makes the noises...not continually...but most of the time. If you stop it, it will start up quietly for a while before beginning to make noise. The size of the load does not seem to affect the noise. When you open the door, the squeeling slows down with the drum and stops. I am at my wits end. I don't want to install a new motor if that isn't what it is. I cannot see any way to lubricate the motor shaft. The drum roller shafts looked good. I lubricated with sewing machine oil when reinstalling. Anyone got any other suggestions?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
We are glad you were able to fix it.
__________________
| Display Modes | |
| Maytag Dryer - first noise, now also electrical problem | RobBroekhuis | Dryer Repair | 6 | 11-08-2009 03:10 PM |
| Maytag LDG4910 gas dryer, loud noise while tubmling | doogle11 | Dryer Repair | 1 | 11-04-2009 03:07 AM |
| Rumbling Noise for Maytag Dryer | Fixer2 | Dryer Repair | 4 | 10-28-2009 02:43 PM |
| Terrible noise when Maytag dryer is running | goorock | Dryer Repair | 7 | 05-01-2009 03:53 AM |
| Maytag dryer drum noise | BillD | Dryer Repair | 3 | 06-23-2008 07:12 AM |
