Discuss
Whirlpool Dryer
 in
Dryer Repair
My dryer will start and work for a while. Then it will shut off for again. After that it will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer
  #1 (permalink)
Old 11-15-2007, 01:25 PM
IrmaE IrmaE is offline
Junior Member
IrmaE is on a distinguished road
Default Whirlpool Dryer
Model Number: LEC8858EQ2   Brand: Whirlpool   Age: More than 10 years
My dryer will start and work for a while. Then it will shut off for again. After that it will start up again by itself and then shut off again. I took the back panel of and checked the heating element and it heats up. I also check the blower and it started up but after a couple of minutes the dryer turned off again. I need to know what else to check for and what part I need to buy.
IrmaE
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 12:37 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Your dryer probably has a Finish Guard future (page 13 in the "Use and care" manual).
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-17-2007, 11:53 PM
Junior Member
Default
Thank you for reply but when my dryer is on it is not on the finish guard cycle. It is on the regular cycle when it turns on and off. So what else could it be?
  #4 (permalink)
Old 11-18-2007, 12:05 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The Finish Guard is not a cycle. It is an option.
If your dryer does not have such option or you did not use it, then I have no idea what could have the dryer to restart by itself.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 01:52 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 12:46 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Whirlpool Dryer won't start Conrad79 Dryer Repair 3 10-30-2007 08:54 AM
UK, Whirlpool dryer , no-nothing theome Dryer Repair 3 10-15-2007 06:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
