Discuss
Kenmore dryer not heating
 in
Dryer Repair
First of all, the model number is 62882, but the kenmore parts site from sears listed two models after searching
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer not heating
  #1 (permalink)
Old 06-18-2011, 01:45 PM
Junior Member
Dando is on a distinguished road
Default Kenmore dryer not heating
Model Number: 62882   Brand: Kenmore   Age: 5 - 10 years
First of all, the model number is 62882, but the kenmore parts site from sears listed two models after searching for 62882: 11062882100 and 11062882101. After using the tech sheet that I had to compare models, I'm fairly sure I have 11062882101.
My dryer stopped heating off and on over the past 1.5 years. It finally quit for good recently. Each time it would stop, I would open it up, troubleshoot, do the diagnostics, read some continuities and resistance, put it back together and it magically worked.
Below is the log from my latest attempt - any help would be greatly appreciated, I'm about to chuck it out the window:
1. Identified model
a. Tech sheet part no. is 3979627
b. Accroding to tech sheet part listing, white model is 62882
c. Secondary number ending in 100 vs 101 - online info conclued this was the 101 by comparing part numbers from tech sheet vs. online 100/101. Particularly because the timer part number on the 101 was never 397xxx and then substituted for the 829xx, but always 829xx also according to tech sheet.
2. Damp dry test
a. Timer advanced (although slowly) after 16 seconds (should this be fast?)
b. End of signal occured
3. Diagnostics test - ensure all electrical inputs/signals are working
a. Was able to activate test mode after the above damp dry test
b. Door switch beeped
c. Moisture sensor beeped with damp cloth and finger
d. All fabric care/temp positions beeped
e. Wrinkle Guard switch (can’t remember, but think it did not)
f. Push to start beeded with door closed
g. Timer cam input (?) did not beep
h. Tried to enter test mode again and could not
4. Supply connections test
a. Neutral to center terminal closed
b. Left plug (with neutral at top) with black (L1) closed.
c. Right plug with red closed.
d. Continuity between L1 terminal and BK terminal on timer
e. Continuity between N terminal of plug and P2-1 on electronic control (in wiring harness)
5. Timer component testing
a. Checked resistance across timer motor - only 2.4k instead of 3k (is this bad
since this only handles movement?)
b. Switching test - all switches test ok, cool down as tested by the V to BK on timed dry seemed a little too far past the “touch up” indicator on the dial,
but I could feel the resistance on the dial kick in as soon as continuity did
kick in.
6. Motor test
a. Measured resistance between motor relay common terminal (COM) and the P2-6
terminal on electronic control, should be 1-6 ohms, measured 2.3 ohms.
b. Measured resistance between motor relay common terminal (COM) and ground. High resistance should be measured. Measured 150+ kilo ohms
7. Door switch test
a. Neutral to P2-6 on electronic control (DOOR) should be closed with door closed, open when door open. Tested correctly.
8. Fabric Care Temperature Switch Test
a. Everything checked fine EXCEPT for all continuity tests with Pin 2 (documented against Pin4), the expected continuities were only ever seen against Pin 5 (not Pin 4). Pin 2 was always open against Pin 4, but was closed to Pin 5 on Medium and Medium High heat (as it should have been against Pin 4 according to tech sheet).
9. Wrinkle Guard switch test
a. Pin 1 and Pin 4 open when WG off confirmed.
b. Pin 1 and Pin 4 closed when WG on conirmed.
10. End of Cycle Signal switch test
a. Pins 1 and 2 against 4 open when OFF
b. Pin 1 and 4 closed when LOW, 2 and 4 open.
c. Pin 1 and 4 open on high, 2 and 4 closed.
11. High Limit Thermostat Test
a. Closed continuity
b. Need to apply heat - should open at 250 F - however this wouldn’t keep the dryer from heating
12. Thermal Cut Off Test
13. Thermal Fuse Test
b. At this point I ’m confused - common problems that lead to heat not working are not being manifested - enough evidence points to faulty controls perhaps?
14. Test mode (again)
a. Entered test mode again
b. Fabric care, wrinkle guard, PTS, and door switch all worked
c. Timer did not work when moved, however when it clicked (perhaps this is what a cam switch is?) it did beep, but after once or twice, stopped, then the whole test mode seemed to be off again.
15. Test mode (again, after doing some random runs to try to “reset” it)
a. FC, WG, PTS, and Door worked.
b. Timer was in auto try mode, beeped each time from More Dry, Normal Dry, to Damp, WG, and back up through, back down, when switched to off and then down into Timer mode, no more beeping, all the way back through to the other off position.
16. Thermistor test
a. Plugged dryer back in, door closed, timed dry, temp on high, WG off, signal high, started normally.
b. Exhaust was not even hot, did not measure temp
c. Unplugged and measured resistance at thermistor, 9.3k ohms. Reference to
11.9k at 70 degrees F and 9.2k at 80 degrees F. Laundry area slightly hotter than rest of house - would estimate temperature is 78, seems to line up.
d. Tech sheet says to replace electronic assembly if thermistor within normal limits. Could the heating element be bad, or would the continuity test of high limit thermostat, fuse, or cut off caught this?
Ads By Google
Related Models
Frigidaire 6289-80A WASHER
Frigidaire 6289-80B WASHER
Frigidaire 6289-87A WASHER
Kenmore 6289307710 KENMORE ELECTRIC RANGE
Kenmore 6289327210 KENMORE ELECTRIC RANGE
Kenmore 6289327220 KENMORE ELECTRIC RANGE
Kenmore 6289327240 KENMORE ELECTRIC RANGE
Kenmore 628932726 KENMORE ELECTRIC RANGE
Kenmore 6289327260 KENMORE ELECTRIC RANGE
Kenmore 6289347100 KENMORE ELECTRIC STOVE
Kenmore 6289347120 KENMORE ELECTRIC STOVE
Kenmore 6289347140 KENMORE ELECTRIC STOVE
Kenmore 6289347160 KENMORE ELECTRIC STOVE
Kenmore 6289347210 KENMORE ELECTRIC RANGE
Kenmore 6289347220 KENMORE ELECTRIC RANGE
Kenmore 6289347240 KENMORE ELECTRIC RANGE
Kenmore 6289347260 KENMORE ELECTRIC RANGE
Kenmore 6289367810 KENMORE ELECTRIC RANGE
Kenmore 6289367811 KENMORE ELECTRIC RANGE
Kenmore 6289367812 KENMORE ELECTRIC RANGE
Kenmore 6289377710 KENMORE ELECTRIC RANGE
Kenmore 6289377810 KENMORE ELECTRIC RANGE
Kenmore 6289377811 KENMORE ELECTRIC RANGE
Kenmore 6289397890 KENMORE ELECTRIC RANGE
Kenmore 6289397891 KENMORE ELECTRIC RANGE
Kenmore 6289397990 KENMORE ELECTRIC RANGE
Kenmore 6289398090 KENMORE ELECTRIC RANGE
Kenmore 6289398190 KENMORE ELECTRIC RANGE
Kenmore 6289398290 KENMORE ELECTRIC RANGE
Kenmore 6289398390 KENMORE ELECTRIC RANGE
Kenmore 6289398391 KENMORE ELECTRIC RANGE
Kenmore 6289398490 KENMORE ELECTRIC RANGE
Kenmore 6289398491 KENMORE ELECTRIC RANGE
Kenmore 628939990 KENMORE ELECTRIC RANGE
Kenmore 6289407310 KENMORE ELECTRIC RANGE
Kenmore 6289407313 KENMORE ELECTRIC RANGE
Kenmore 6289407320 KENMORE ELECTRIC RANGE
Kenmore 6289407323 KENMORE ELECTRIC RANGE
Kenmore 6289407340 KENMORE ELECTRIC RANGE
Kenmore 6289407343 KENMORE ELECTRIC RANGE
Kenmore 6289407360 KENMORE ELECTRIC RANGE
Kenmore 6289407363 KENMORE ELECTRIC RANGE
Kenmore 6289427000 KENMORE ELECTRIC STOVE
Kenmore 6289427001 KENMORE ELECTRIC STOVE
Kenmore 6289427020 KENMORE ELECTRIC STOVE
Kenmore 6289427021 KENMORE ELECTRIC STOVE
Kenmore 6289427040 KENMORE ELECTRIC STOVE
Kenmore 6289427041 KENMORE ELECTRIC STOVE
Kenmore 6289427100 KENMORE ELECTRIC STOVE
Kenmore 6289427120 KENMORE ELECTRIC STOVE
Kenmore 6289427140 KENMORE ELECTRIC STOVE
Kenmore 6289427160 KENMORE ELECTRIC STOVE
Kenmore 6289427210 KENMORE ELECTRIC RANGE
Kenmore 6289427220 KENMORE ELECTRIC RANGE
Kenmore 6289427240 KENMORE ELECTRIC RANGE
Kenmore 6289427260 KENMORE ELECTRIC RANGE
Kenmore 6289427310 KENMORE ELECTRIC RANGE
Kenmore 6289427313 KENMORE ELECTRIC RANGE
Kenmore 6289427320 KENMORE ELECTRIC RANGE
Kenmore 6289427323 KENMORE ELECTRIC RANGE
Kenmore 6289427340 KENMORE ELECTRIC RANGE
Kenmore 6289427343 KENMORE ELECTRIC RANGE
Kenmore 6289427360 KENMORE ELECTRIC RANGE
Kenmore 6289427363 KENMORE ELECTRIC RANGE
Kenmore 6289427810 KENMORE ELECTRIC RANGE
Kenmore 6289427910 KENMORE ELECTRIC RANGE
Kenmore 6289427911 KENMORE ELECTRIC RANGE
Kenmore 6289428210 KENMORE ELECTRIC RANGE
Kenmore 6289428211 KENMORE ELECTRIC RANGE
Kenmore 6289428212 KENMORE ELECTRIC RANGE
Kenmore 6289437610 KENMORE ELECTRIC RANGE
Kenmore 6289437611 KENMORE ELECTRIC RANGE
Kenmore 6289437612 KENMORE ELECTRIC RANGE
Kenmore 6289437910 KENMORE ELECTRIC RANGE
Kenmore 6289447000 KENMORE ELECTRIC STOVE
Kenmore 6289447001 KENMORE ELECTRIC STOVE
Kenmore 6289447020 KENMORE ELECTRIC STOVE
Kenmore 6289447021 KENMORE ELECTRIC STOVE
Kenmore 6289447040 KENMORE ELECTRIC STOVE
Kenmore 6289447041 KENMORE ELECTRIC STOVE
Kenmore 6289447100 KENMORE ELECTRIC STOVE
Kenmore 6289447120 KENMORE ELECTRIC STOVE
Kenmore 6289447140 KENMORE ELECTRIC STOVE
Kenmore 6289447160 KENMORE ELECTRIC STOVE
Kenmore 6289507710 KENMORE ELECTRIC RANGE
Kenmore 6289646800 KENMORE ELECTRIC RANGE
Kenmore 6289666800 KENMORE ELECTRIC RANGE
Kenmore 6289666840 KENMORE ELECTRIC RANGE
Kenmore 6289666860 KENMORE ELECTRIC RANGE
Kenmore 6289696800 KENMORE ELECTRIC RANGE
Kenmore 6289696840 KENMORE ELECTRIC RANGE
Kenmore 6289696860 KENMORE ELECTRIC RANGE
Amana 629-3N Room Air Conditioner
Amana 629-3W Room Air Conditioner
Kenmore 629.12103  COOKTOPS
Kenmore 629.12104  COOKTOPS
Kenmore 629.20135  ELECTRIC RANGE
Kenmore 629.20236  ELECTRIC RANGE
Kenmore 629.20237  ELECTRIC RANGE
Kenmore 629.20239  ELECTRIC RANGE
Kenmore 629.20245  ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 629.21136  Built-In Oven, Electric
Kenmore 629.21137  Built-In Oven, Electric
Jenn-Air 629.21138 Walloven - S/c Ele
Kenmore 629.21238  WALL OVEN
Kenmore 629.21239  WALL OVEN
Kenmore 629.21336  WALL OVEN
Kenmore 629.22001  COOKTOP
Kenmore 629.22112  COOKTOPS
Kenmore 629.22113  COOKTOPS
Kenmore 629.22114  UPDRAFT ELECTRIC COOKTOP
Kenmore 629.22115  UPDRAFT ELECTRIC COOKTOP
Kenmore 629.22116  ELECTRIC COOKTOP
Kenmore 629.22401  COOKTOP
Kenmore 629.40485  FILLER KIT
Kenmore 629.40486  FILLER KIT
Kenmore 629.40489  FILLER KIT
Kenmore 629.42015  COIL MODULE
Kenmore 629.42019  COIL MODULE
  #2 (permalink)
Old 06-18-2011, 01:50 PM
Junior Member
Default
What I would like to next investigate:
1. How to determine if actual heating element is bad? Continuity between heat element and thermal cut off exists, what about resistance - no number to test from tech sheet.
2. Controls seem like something weird is going on - timer seems off during the beep test mode, the machine seems to go haywire a bit during the beep test mode and not want to go back into it, and finally the thermistor resistance reading fine indicates the electronic control assembly is to blame (according to tech sheet).
3. If I have to replace the electronic assembly and timer, the kenmore parts site @ sears lists them for $80 each. Better to put the $160 towards the new washer/dryer combo the wife would like?
  #3 (permalink)
Old 06-18-2011, 02:28 PM
Junior Member
Default
Tested the 240 outlet successfully.
Tested heating element at 10 ohms.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer not heating mikmat63 Dishwasher Repair 0 01-13-2011 02:18 PM
Kenmore dryer not heating MBKENMORE Dryer Repair 1 09-08-2010 12:47 PM
Kenmore Dryer not heating boomerpaula Dryer Repair 0 06-23-2010 06:22 PM
kenmore gas dryer not heating car14 Dryer Repair 0 06-07-2010 01:24 PM
kenmore dryer not heating doitmyselfcuzIcan Dryer Repair 0 07-03-2009 03:00 PM
