Discuss
dryer problem
 in
Dryer Repair
my dryer stopped working after i used it the night before i put a load in and let it run
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer problem
  #1 (permalink)
Old 11-15-2007, 12:38 PM
Sshawn_L Sshawn_L is offline
Junior Member
Sshawn_L is on a distinguished road
Default dryer problem
Model Number: LER5620KQ1   Brand: Whirlpool   Age: 1 - 5 years
my dryer stopped working after i used it the night before i put a load in and let it run and went to sleep when i opened it in the morning it was hot inside but had not been running and i could see from inside the drum with the door open the element was glowing but the dryer wasent running, if i turn the knob to dry (nomatter what setting) i can see the element startglowing from inside the drum with the door open, but it dosent sound like its doing anything or move or make any noise, the light works when the door opens i dont know what is wrong and would appreciate any help i can get....also i noticed a while back i was drying a load and fell asleep and the trier never shut off but has been ok since
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-15-2007, 06:47 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
It Seem The Element Must Have Shorted To Ground May Need To Check Dryer Vent For Restrictions May Need New Element
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer problem KevinJ67 Dryer Repair 0 10-23-2007 07:57 AM
GAS Dryer Problem Miss Dryer Repair 1 10-22-2007 06:56 PM
Dryer heat problem Dale Dryer Repair 1 10-02-2007 04:54 AM
gas dryer heating problem sakks Dryer Repair 1 09-14-2007 06:45 AM
Dryer Problem TerryW Dryer Repair 2 09-11-2007 09:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
