Discuss
Whirlpool GEW9250 dryer gets too hot
 in
Dryer Repair
Dryer gets too hot, and stays hot. I have replaced the thermal fuse and thermistor, but it did not help.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool GEW9250 dryer gets too hot
  #1 (permalink)
Old 06-17-2011, 03:30 PM
kp1 kp1 is offline
Junior Member
kp1 is on a distinguished road
Default Whirlpool GEW9250 dryer gets too hot
Brand: Whirlpool   Age: 5 - 10 years
  #2 (permalink)
Old 06-17-2011, 07:15 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Air flow problem
What you have is an air flow issue. If the heated air cannot escape the unit is going to overheat. Clean out you filter/blower housing and outside vent. Use rigid metal vent piping. If the thermistor didn't correct the problem then maybe the control is faulty.
  #3 (permalink)
Old 06-18-2011, 09:11 AM
kp1 kp1 is offline
Junior Member
Default
Thanks-
I have good air flow coming out of the vents. What is the control, and is there a way for me to test it?
  #4 (permalink)
Old 06-20-2011, 04:42 PM
Senior Expert
APP Volunteer
Default Duet Dryer Service manual
Service manual for Duet dryer
Note use the tech sheet in your appliance for diagnostics.
Use the service manual for a reference and party on!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 4 06-18-2011 06:42 AM
how do I get to the dryer belt on a whirlpool electric dryer? jchase Dryer Repair 1 04-16-2011 02:23 PM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 7 12-27-2010 03:34 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
