My Whirlpool LGR4634JQ0 dryer is not heating up the tumbler works fine but it will spin indefinately. When put on timed dry the dryer will run and shut down but with out heating up. Two years ago I replaced the solenoids on the gas valve to fix a similar problem but this time I do not see the ignitor starting up and don't hear the valves opening.
Thanks for the link. I watched the video and it was the thermal fuse. I have it on order and hope that will take care of it.
Your welcome and yeah the thermal fuse is pretty common part to fail ... I usually replace one a day and order them by the dozen ... Let me know how things go.
The thermal fuse fixed it. I came home for lunch on Saturday put in the new fuse and had the kids start doing laundry and all is working well thanks again.
Your welcome and dont forget to look us up if you have anymore problems in the future.
