| » Maytag Neptune Electric Dryer (MDE3000AYW )will not start |
Model Number: MDE3000AYW Brand: Maytag Age: 5 - 10 years
Maytag Neptune Electric Dryer Model #MDE3000AYW purchased in 1999.
Worked fine in the morning, but in the afternoon but it would not start. 1. It has power. 2. The door switch works. 3. I suspected the push-to-start switch, so I opened up the rear top panel and got my voltage tester out and I have 120V to the red wires on one side of the switch. 4. I disconnected the switch and put my continuity tester on each contact. I have continuity between the two contacts when I hold the button down, but no continuity when I release the button. 5. I reconnected the switch and jumpered the two red wires that connect to contact #1 to the yellow wire that connect to contact #2. Still won't start. Is that normal behavior? Are there any other tests I can try? Could it be the Drive Motor? Ads By Google Related Models |
Model MDE3000AYW Here is a service manual http://www.servicematters.com/maytag...s/16023110.pdf Check the two thermal fuses in the motor circuit If this is the culprit clean the inside of the unit including the blower wheel. Also clean and check your vent system
__________________
| Display Modes | |
| maytag electric dryer will not start | jamesdonald | Dryer Repair | 1 | 11-19-2009 02:40 PM |
| Maytag Electric Dryer won't start,no sound | Pennell | Dryer Repair | 2 | 11-13-2009 03:43 AM |
| maytag electric dryer won't start | shattycat | Dryer Repair | 1 | 08-05-2009 05:33 AM |
| maytag neptune electric dryer wont operate | pandsshearer | Dryer Repair | 1 | 03-06-2009 04:42 AM |
| maytag gas dryer hums but wont start.. electric smell. | elsanto | Dryer Repair | 0 | 12-31-2007 06:49 AM |
