My Gas Dryer Buzzes when I push the Start button. Sometimes it will try to start, then cycle off. A few minutes later it retries to actuate the drum. It will do this until it starts or I open the dryer door to stop the cycle. I read in other posts to possibly clean the motor with an air tank and a sweeper. Any other ideas?
ok.. i took off the drum and cleaned the motor and housing. Without the drum, the motor engages every time no issues. with the drum on, it stalls. If I lift the cover and turn the drum when it is trying to start it engages ands starts. So what is causing to be a slow or no start with the drum on? any ideas?
