Discuss
whirlpool squeel
 in
Dryer Repair
any help would be greatly appreciated to silence this issue.... not appalling yet but loud enough
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool squeel
  #1 (permalink)
Old 07-30-2007, 08:36 PM
put4brdee put4brdee is offline
Junior Member
put4brdee is on a distinguished road
Default whirlpool squeel
Brand: Whirlpool   Age: 5 - 10 years
  #2 (permalink)
Old 07-30-2007, 09:50 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
It could be the drum rollers, belt idler or motor.
You can tell by taking the dryer apart and turning each part by hand.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #3 (permalink)
Old 07-31-2007, 06:16 AM
Junior Member
Default
thanks... where do I start...what am i looking for... handy but first attempt at appliance repair! then where do i get parts?
  #4 (permalink)
Old 07-31-2007, 07:21 PM
Senior Expert
APP Volunteer
Default
Disconnect the power to the dryer.
Remove the two screws on top near the lint screen.
There are two clips in front of the dryer that hold the top down. Use a putty knife or flat blade screwdriver to push the clips in and lift the top.
Now remove the front of the dryer. There are a couple of inside screws that hold it on. You will be able to see the screws looking down from the top of the dryer.
Once you have the top lifted and the front off you can remove the belt from the idler wheel.
Then take the drum out and you will be able to easily see everything.
Start turning and spinning things by hand and you should be able to tell what is making the noise.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #5 (permalink)
Old 08-01-2007, 06:53 AM
Junior Member
Default
thanks alot
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
