| » Dryer does not heat |
Model Number: LEN1000PQ1 Brand: Whirlpool Age: More than 10 years
I have a len1000pq1 dryer the heat is not working and the timer doesnt move could that be the timer for both problems, the dryer does run
Quote:
The timer, could be the problem, and a very good guess. Part number: AP3131541 But, I would suspect a malfunctioning motor switch or damaged white/black wire from the motor. Part number: AP3094245 The motor supplies the L2 power to both the heater and timer motor, and is a more likely failure at this point. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
