blanerings
#1 Posted : Tuesday, June 14, 2011 10:55:44 AM(UTC)
blanerings
Our GE Dryer is Squeeking like crazy. Do I need a new Drum Bearing Kit? Possibly an additional part or parts? Or something totaly different and a bit more simple fix? Thanks..... Going bonkers in Central Illinois! blane
Joe / APP Team
#2 Posted : Tuesday, June 14, 2011 12:20:02 PM(UTC)
Joe / APP Team
Blane,
You're right on target, you will most likely need the drum bearing kit,
Part number: AP2619300
The other possibilities , something metal stuck to the front panel seal, drum glides.
The idler pulley, usually creates a deeper rumbling type sound when it deteriorates,
Depending on the condition of the drum slides, I would at least clean,lightly sand smooth the glide surfaces and dab a bit of silicone lube on the pads, or replace them.
Good Luck,
#3 Posted : Tuesday, June 14, 2011 3:32:33 PM(UTC)
Just to add my 2 cents...
You also may want to check the front drum bearing and the slides (#313 & #316 on the diagram).
- The front drum bearing Part number: AP3790641
- The white slide (two needed) Part number: AP2041815
Dennis Mortimer
#4 Posted : Tuesday, July 5, 2011 5:01:38 PM(UTC)
Dennis Mortimer
Hello, I have a GE gas dryer that is squeeking. Will the 3 parts below work for my model and do you have any repair diagrams showing how to replace these items?
#5 Posted : Tuesday, July 5, 2011 5:23:57 PM(UTC)
Dennis,
Your dryer is very similar to the previous model. So, you can use the same instructions.
Here are the breakdown diagrams and Replacement parts for General Electric DQSR483GE0WW Gas dryer | AppliancePartsPros.com
eeadams33
#6 Posted : Friday, September 16, 2011 1:53:52 PM(UTC)
eeadams33
Gene,
I bought and just replaced the Drum Bearing and slides. Works great!! I still have questions if I placed the slides (2 green and 2 white) in the proper order, as mine were completely gone (except for the 1st white one on the right) and I can't find any instructions as to what order they go. Looking at the dryer, starting on the right (to left), I went white, green, white, green... Am I correct??
Joe / APP Team
#7 Posted : Friday, September 16, 2011 2:06:55 PM(UTC)
Joe / APP Team
Originally Posted by: eeadams33 Go to Quoted Post
Gene,
Gene, Almost right,
using your terminolgy it should be: white, green, green, white (greens on top, whites on the sides).
But,
Great job ,
