how to replace tumbler rear seal
Originally Posted by: brbuilder how to replace tumbler rear seal BR, After you dismantle the dryer interior components, you 'll have access to the rear bulkhead and tumbler seal. the rear bulkhead will have "tabs" that you'll insert the seal into (in a clockwise direction), you do not cut or trim the seal, it needs to overlap the starting point, then you fold it up and install the drum and the remainder of the interior components. for reference only Part number: AP4042261
At present we cannot transmit a service manual in a PDF file, so here is the service manual part number, you may want to use the internet and see if you can find a copy there, or we can copy and fax the information you'll need. Service manual part number 16000416 Good Luck, :cool: :cool: :cool:
