Discuss
bypass thermal fuse?
 in
Dryer Repair
Can I bypass thermal fuse somehow to confirm dryer operation?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » bypass thermal fuse?
  #1 (permalink)
Old 11-14-2007, 12:35 PM
markus markus is offline
Junior Member
markus is on a distinguished road
Default bypass thermal fuse?
Model Number: LEC8858EQO   Brand: Whirlpool   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-14-2007, 12:59 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What exactly is wrong with your dryer?
The best thing you can do is to check the thermal fuse (#7 on the bulkhead part break down diagram) for continuity.
Replace it if it's open.
The thermal fuse
- The part number for the thermal fuse AP3132867
According to the manufacturer instructions, if the thermal fuse is open, the cycling thermostat has to be replaced too.
The cycling thermostat
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Whirlpool dryer Model LEC8858EQ0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-14-2007, 01:07 PM
Junior Member
Default
The dryer will not turn on, I have power. Was informed it may be the fuse. I do not have meters at my disposal.
  #4 (permalink)
Old 11-14-2007, 01:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to perform the troubleshooting according to the wiring diagram bu you can not do it without a simple meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Where's the thermal fuse? deburrito Dryer Repair 10 08-21-2008 07:52 PM
Help with Replacing Thermal Cutoff Kit ReagaNoah Dryer Repair 4 08-16-2008 04:17 PM
thermal cut off fuse keeps blowing djnew york Dryer Repair 0 11-12-2007 03:43 PM
Thermal fuse location Dbowls Dryer Repair 4 08-29-2007 03:37 PM
my fridge keeps tripping switch in fuse box jamie7 Refrigerator & Freezer Repair 1 08-09-2007 06:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
