Daughter dried some clothing, it worked fine. Went back a while later to run another load, it won't start.
Status lights out, no inside light. "Estimated Time Remaining" is lit with time left, but if you press the "START", the # starts flashing, it beeps, but will not start.
Diagnostic test gets a "6E" code on the display - I've seen another source that indicates that this is the door switch.
Ideas?
Thanks, J
