| » dryer gets too hot on every heat setting |
Model Number: GEQ9800PW1 Brand: Whirlpool Age: 5 - 10 years
Vent is clear and changing heat setting to lower setting doesn't seem to
make much difference. The case still seems too hot. Ads By Google Related Models |
Replacement parts for WHIRLPOOL GEQ9800PW1 27" ELECTRIC DRYER | AppliancePartsPros.com See the attachment for the tech sheet. First I would check the heating element. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 8 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high all the time. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use.
__________________
Could the drum seal be bad?
Could be, see the following Dryer is too hot on all settings I am assuming that the "0 ohms" (element to frame) is an error as 0 ohms would be a dead short. So I am assuming you mean infinite ohms (open) which is what it should be.
__________________
| Display Modes | |
| Whirlpool Dryer, getting Heat on NO heat setting. | gph1 | Dryer Repair | 1 | 09-24-2010 01:09 PM |
| Very little heat at any setting | cousineauj | Dryer Repair | 3 | 06-07-2010 03:25 AM |
| Dryer only starts if it is on "low heat" setting | jpbarras | Dryer Repair | 1 | 05-04-2010 02:49 PM |
| frigidaire dryer doesn't heat on high setting | Alexis46 | Dryer Repair | 1 | 09-27-2009 07:55 PM |
| GE Dryer wil not heat up on anything but timed setting. | todv | Dryer Repair | 0 | 11-16-2008 05:20 PM |
