| » belt/drum/pully |
Model Number: lgr7646eq0 Brand: Whirlpool Age: 5 - 10 years
ok dryer not getting hot going to replace igniter removed front panel. drum and belt pully came out of base. can not get pully and belt tension back to normal,pully support has no screw hole in base looks like it just clips in.not sure.
The first thing: are you sure the problem is a bad igniter? Did you check the igniter for continuity?
About the idler pulley: yes, it just clips in. After you placed the idler pulley, make a loop on the belt, put it through the idler pulley (under the roller) and around the motor pulley. The belt configuration picture is attached. - Here are the break down diagrams for the Whirlpool dryer Model LGR7646EQ0 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| how do I remove the metal cabnet and repace a new drum belt | Tinas7 | Dryer Repair | 2 | 01-03-2008 05:04 PM |
| Cannot put belt on drum properly | jackd3 | Dryer Repair | 2 | 10-12-2007 08:34 PM |
| not turning of the drum | scott glynn | Washer Repair | 1 | 10-12-2007 11:51 AM |
| cannot put drum belt back on tight | frank | Dryer Repair | 1 | 08-10-2007 09:37 PM |
| drum will not spin | maria camacho | Dryer Repair | 1 | 07-20-2007 09:56 PM |
