Discuss
Dryer
 in
Dryer Repair
My dryer won't heat anymore. Everything runs fine but it won't heat on any setting. Please advise. Thank you Ads
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer
  #1 (permalink)
Old 06-13-2011, 07:06 AM
Junior Member
smartenson is on a distinguished road
Default Dryer
Brand: Admiral   Age: 1 - 5 years
Ads By Google
  #2 (permalink)
Old 06-15-2011, 01:55 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
First check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The motor etc. usually requires 120 volts while the heating element needs the full240.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next unplug the unit and check the heating coil with a meter, most are in the 10 to 12 ohm range.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
