Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer (http://forum.appliancepartspros.com/dryer-repair/247828-dryer.html)
smartenson 06-13-2011 07:06 AM
Dryer
My dryer won't heat anymore. Everything runs fine but it won't heat on any setting. Please advise. Thank you
denman 06-15-2011 01:55 AM
A model number may help others help you.
First check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The motor etc. usually requires 120 volts while the heating element needs the full240.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next unplug the unit and check the heating coil with a meter, most are in the 10 to 12 ohm range.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
