Discuss
Dryer wont turn on
 in
Dryer Repair
Breaker is fine and dryer has power. Lifted dryer top and checked door switch, No power to switch. Removed back
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont turn on
  #1 (permalink)
Old 02-27-2009, 09:38 AM
Junior Member
mechaniac is on a distinguished road
Default Dryer wont turn on
Model Number: LER4634jq1   Brand: Whirlpool   Age: 5 - 10 years
Removed back panel to control console, No power to start button.
Checked power to timer, OK.
Pulled rear dryer panel and checked for volatge at motor. OK.
It is obviouse that in order for the motor to work it has to recieve power from the timer to engage the motor?
Is roblem at timer?
Ads By Google
Related Models
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
  #2 (permalink)
Old 02-27-2009, 11:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Model LER4634JQ1
Here is a wiring diagram
https://www.servicematters.com/docs/...%208528187.pdf
Did you measure L1 to L2 (240 volts), also L1 to Neutral and L2 to Neutral (120 volts)
Measuring from where to where
Is this across the motor ? Again where to where?
Timer motor should not have power unless the main motor is running.
Where to where, cannot be OK or the motor would run unless your motor is shot.
Is roblem at timer?
Cannot tell from your description, possible but unlikely.
A common cause is the thermal fuse in the motor circuit.
Item 19 in Section 3
Unplug the machine
Pull one wire from the fuse
Measure across it
Should be 0 ohms
If open replace
If you do not have a multimeter (ohmmeter)
Unplug the machine
Short the two wires from the machine together
Tape them up so they cannot short to the frame
And give it a try
If it now runs replace the fuse ASAP as it is a safety device.
If it was the fuse give the interior a good cleaning/check including the blower wheel. Also clean/check your vent system
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont turn fastfreddie68 Dryer Repair 1 02-02-2010 02:46 AM
dryer wont turn on jake@studioyoshida.com Dryer Repair 1 11-10-2009 04:18 PM
Dryer wont turn yumickapowell Dryer Repair 1 09-20-2009 03:29 AM
Dryer wont turn on Julierob Dryer Repair 3 04-14-2008 03:40 AM
Dryer wont turn on angierg Dryer Repair 0 09-04-2007 03:52 PM
